[fusion-trac] #649: Theme widget: Cannot theme parcels layer
Fusion
trac_fusion at osgeo.org
Tue Jul 12 05:06:31 PDT 2016
Reporter: jng | Owner: jng
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 2.0
Severity: Major | Keywords:
Browser: All | External ID:
Operating System: All | state: New
Enable errors in PHP.ini
Load Sheboygan map in a Flexible Layout
Run the theme widget
Theme on Parcels -> RTYPE property
Apply the theme. It fails because PHP reports warnings about {{{EntityRef:
expecting ';' in Entity}}} in {{{DOMDocument::loadXML}}}
This is most likely because of the theme rule for {{{'S&W'}}} does not
properly escape the {{{&}}} character when generating the layer definition
XML.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/649>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
