[fusion-trac] #656: Error when select Redline object
Fusion
trac_fusion at osgeo.org
Mon Mar 6 20:14:45 PST 2017
Reporter: zhanga | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: 2.3
Component: Widgets | Version: 2.0
Severity: Major | Keywords:
Browser: All | External ID:
Operating System: All | state: New
Clients when using IE 11 encounter a fusion error when attempting to
select a red line object using the Select feature off the main menu versus
the select button within the widget.
Steps to Reproduce:
1. Create multiple redline layers (3 layers), each with a circle redline
entity.
2. Using the Select tool button (CHOOSE THE SELECT ARROW ICON BUTTON FROM
THE MAP WINDOW, NOT the Select button in Edit Redline taskpane on the
left hand side window), select the any redline from the second or third
redline layer you just placed. Note: A fusion error will be thrown.
Note: Sometimes the error will not pop up right away from the steps above
and the user needs to click the select button and then select in the area
off the map (in the ocean, where no redlines exist).
Ticket URL: <http://trac.osgeo.org/fusion/ticket/656>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
