[fusion-users] Problem with layer hiding and showing.
Berdel, Brian brian.berdel at mcmtrans.com
Wed Aug 6 10:46:15 EDT 2008
Here is code to show a layer (just replace layerName)
    var mapWidget = Fusion.getWidgetById('Map');
    var layer = mapWidget.aMaps[0].getLayerByName(layerName);
    layer.show();
Brian
From: fusion-users-bounces at lists.osgeo.org [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Tómas Guðmundsson
Sent: Wednesday, August 06, 2008 10:18 AM
To: Kenneth Skovhede, GEOGRAF A/S
Cc: fusion-users at lists.osgeo.org
Subject: RE: [fusion-users] Problem with layer hiding and showing.
Thanks.
I am trying to use map.showLayers() but I'm not sure what parameters it needs.
Does anyone know where the definition of layer.show() and layer.hide() as well as
map.showLayers() and map.hideLayers().
Regards,
Tómas.
From: Kenneth Skovhede, GEOGRAF A/S [mailto:ks at geograf.dk]
Sent: 6. ágúst 2008 13:47
To: Tómas Guðmundsson
Cc: Mike Adair; fusion-users at lists.osgeo.org
Subject: Re: [fusion-users] Problem with layer hiding and showing.
I have no idea how to do this in fusion, but you will likely have to run through the layer list when doing a "layer.show()".
I think there is a call that updates the map without returning the image. You can use that, but it will require multiple server calls over http.
Regards, Kenneth Skovhede, GEOGRAF A/S
Tómas Guðmundsson skrev:
Thanks Kenneth,
I'm trying to figure it out how I put multiple GUIDS into the mapagent request.
Only way I know how to do it is with layer.show(). I'll look more into it but if you
Have it on the top of your head, any info would be great thanks.
Regards,
Tómas.
Sent: 6. ágúst 2008 10:57
the "ShowLayers" parameter in the "GETMAPIMAGE" call, can take multiple GUIDs, so you should send:
SHOWLAYERS=118e0096-0000-1000-8000-001b2418ab2d,1192c52c-0000-1000-8000-001b2418ab2d,119062dc-0000-1000-8000-001b2418ab2d
Mike, all.
With some debugging this is what I find:
console.log('showing :', group.layers[j], ' - ', group.layers[j].layerName);
showing : Object uniqueId=118e0096-0000-1000-8000-001b2418ab2d - HV_loki
showing : Object uniqueId=1192c52c-0000-1000-8000-001b2418ab2d - HV_brunnar
showing : Object uniqueId=119062dc-0000-1000-8000-001b2418ab2d - HV_lagnir
This is normal, this is what it should do. And this is printed out when each layer
calls a method "layer.show()". Now, there is only one mapagent call that displays
this.
clientagent    Fusion Viewer
showLayers     119062dc-0000-1000-8000-001b2418ab2d
operation      GETMAPIMAGE
And evidently on my map, the only layer that get's displayed is HV_lagnir. If I change
the order, the last one always appears. However, the legend and "group.layers[j].visible"
all result in true. It would be kind of silly to wait for 3 images to display 3 layers,
so I'm wondering how this can be solved.
Regards,
Tómas
-----Original Message-----
Sent: 6. ágúst 2008 09:05
To: Mike Adair
Mike,
I'm afraid that all I found was the 'showlayers' parameter. And it
was some kind of a hash,
showLayers     0f682be6-0000-1000-8000-001b2418ab2d
I don't quite know how to decrypt that but any help would be appreciated.
F.y.i. this is the kind of hash that would be correct with the layers
appropriately displayed.
showLayers     0f65c98c-0000-1000-8000-001b2418ab2d
The delta is only in the first part.
Regards,
Tómas.
Sent: 5. ágúst 2008 19:20
Tomas,
You should check the value of the 'showlayers' and 'hidelayers'
parameters in the sequence of mapagent calls to GETMAPIMAGE. Those are
the parameters that turn layers on or off. If they are what you are
expecting, then it's possible that there is a problem with specifying
those params, e.g. they should be comma-separated and they are not, or
vice versa.
Mike
Tómas Guðmundsson wrote:
	Sorry about that. Everything about "If I do nothing else but reload
	the map (i.e. pan the map, zoom or refresh it) the correct layers are
	displayed on the map (all 3 or none at all).
	So I figure this has something to do with timing or something like
	that, of the fetching of the map itself?"
	Is wrong. So ignore that.
	Rgds.
	Tómas
	[mailto:fusion-users-bounces at lists.osgeo.org] *On Behalf Of *Tómas
	Guðmundsson
	*Sent:* 5. ágúst 2008 13:36
	*To:* fusion-users at lists.osgeo.org
	*Subject:* [fusion-users] Problem with layer hiding and showing.
	Hi all.
	I currently have function that I am using that systematically goes
	through an array it's passed and walks through the layer legend to see
	if it finds a layer. So for every layername in a layerarray, I check
	if that layer exists and then if the checkbox is checked I show it,
	else I hide it. Now I've been debugging this and for an array of 3
	layers (this also happens for layers more than 1), I get 3 times the
	debug message "showing layer", when I check the checkbox again I get
	the debug message "hiding layer" 3 times as well.
	So I know this is working properly, however Mapguide Server does not
	think so. Or at least the images I get back from the server are
	missing one layer (the first one, every time). So according to the
	legend all 3 layers are visible. However, the map shows everyone
	except the first one. Now I figured this was weird, especially since
	when I try to hide them, they all are hidden except the first one
	which is now visible. And now for the final twist.
	If I do nothing else but reload the map (i.e. pan the map, zoom or
	refresh it) the correct layers are displayed on the map (all 3 or none
	at all).
	Please let me know if this is not clear to you and I'll try to explain
	better, but I find it weird I can not hide more than 2 layers at a time.
	Kind regards,
	Tómas
	fusion-users mailing list
	http://lists.osgeo.org/mailman/listinfo/fusion-users
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20080806/ad104841/attachment-0001.html
More information about the fusion-users mailing list
