[fusion-users] Re: [mapguide-users] Fusion Load Time (was: Fusion + Oracle datasource problem)
Paul Spencer pagameba at gmail.com
Fri Aug 22 08:19:22 EDT 2008
Excellent guide!
I will be adding (soon) an enhancement to the single file build that
will also compress the CSS files (YUI compressor does CSS too!) and a
method of combining all the icon images into a single image strip and
producing a CSS file that allows referencing those images in buttons
from the strip, reducing the number of image assets that have to be
loaded to a minimum as well.
I'll include documentation in your wiki page when its done ;)
Cheers
Paul
On 21-Aug-08, at 2:53 PM, Jason Birch wrote:
> If you are using the SVN version, you may also want to use the Ant
> build system to compile your Fusion install into a single compressed
> binary.  For production sites, it’s recommended to write your
> ApplicationDefinition out to a file and include this in the build as
> well.
> This is easier than it sounds (if you’re running from SVN) and makes
> a real difference in load time.
> If you don’t already have one, download a current JDK (SE) package
> from Sun.
> http://java.sun.com/javase/downloads/index.jsp
> Most versions appear to work; I’m currently using JDK5.  Ensure that
> this is the first Java on the path and, maybe, set JAVA_HOME.  You
> can do this temporarily as part of your build routine too (I am, so
> I don’t mess up my Oracle drivers).
> Next download the Ant binaries:
> http://ant.apache.org/bindownload.cgi
> and place in a top-level folder like C:\Ant\
> Finally, obtain the YUI compressor
> http://developer.yahoo.com/yui/compressor/
> From the author’s website
> http://www.julienlecomte.net/yuicompressor/
> and unzip it in a top-level folder like C:\YUI\
> Now, go to your SVN repository and modify the YUIcompressor property
> to point to the location of your jar:
> http://trac.osgeo.org/fusion/browser/trunk/build.xml#l92
> With this in place, you’re ready to build.  In my case I mapped a
> drive to my Fusion checkout, and opened a command window on my PC
> pointing to that directory.  Following the instructions on the
> Fusion wiki
> http://trac.osgeo.org/fusion/wiki/ANTBuildSystem
> I typed:
> ant singlefile
> This seemed to go well, so I deleted the build directory and typed
> Ant singlefile –DappDef=x:/myapp/applicationdefinition.xml
> This also worked well.
> Because I am running my test site directly against SVN, I copied the
> FusionSF-compressed.js (or something like that) file from the build
> directory back into the main fusion/lib directory, and pointed my
> template to it.  Load time decreased significantly.
> I’ve been meaning to add this to the Fusion wiki; just haven’t had
> time to write it up and test it yet.  Now I’m half done J
> Jason
> From: Andrew DeMerchant
> Subject: Re: [mapguide-users] Fusion + Oracle datasource problem
> What sort of webserver are you running? I'm using IIS5, and just
> enabled compression using FlatCompression (www.flatcompression.org)
> and it has dramatically sped up my initial load times for Fusion....
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
More information about the fusion-users mailing list
