[fusion-users] Maptips on Mapserver
Marc Pfister mpfister at enplan.com
Tue Aug 26 20:04:34 EDT 2008
It's easy to just take the current maptip code which handles the mouse
movement detection and modify it to fire off a Map.Query instead of the
MG one. However, when you do this every time you stop moving the mouse
you trigger a redraw to show the selection highlighted.
So where exactly is the query code? I think I'll just tweak that that to
pass the query back to the maptip code.
Also, speaking of queries - is there  a way to change the selection
highlight color and lineweight?
Marc
From: pdescham49 at gmail.com [mailto:pdescham49 at gmail.com] On Behalf Of
Paul Deschamps
Sent: Tuesday, August 26, 2008 11:46 AM
To: Marc Pfister
Cc: fusion-users at lists.osgeo.org
Subject: Re: [fusion-users] Maptips on Mapserver
To my knowledge no.. but you are correct it would be quite simple to
develop one using the select widget
All that is needed is to have some logic to detect mouse movement and
when the mouse is still have it fire a query.
and output the results.
Cheers
Paul D.
On Tue, Aug 26, 2008 at 2:36 PM, Marc Pfister <mpfister at enplan.com>
wrote:
Has anyone implemented maptip-like functionality for Mapserver instead
of MapGuide? It seems like you could switch Fusion to using the generic
selection tool instead of the MG specific one.
n
Marc Pfister
Geospatial Data Manager
ENPLAN
530/221-0440 x108
530/221-6963 Fax
fusion-users mailing list
http://lists.osgeo.org/mailman/listinfo/fusion-users
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20080826/0a6c5b7b/attachment.html
More information about the fusion-users mailing list
