[fusion-users] Add HTML table inside the Jx.TreeFolder object
Rodolfo Moreno
rmoreno at voxiva.com
Fri Aug 29 17:15:35 EDT 2008
Hi Paul,
excuse my rudeness for writing to you straight, but I know you are a
seasoned developer in Jx.
I want to show a HTML table after doing click to a Jx.TreeFolder
/* add a folder to the tree */
var folder = new Jx.TreeFolder({label: 'My Folder'});
tree.append(folder);
/* put an item into the folder */
var item = new Jx.TreeItem({label: 'item ' + i});
folder.append(item);
This is a sample that I found in zip file of fusion. It shows how put an
item as a text into folder,
but I would like to append a HTML table into folder, is it possible?
Thanks in advance
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/Add-HTML-table-inside-the-Jx.TreeFolder-object-tp793112p793112.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users
