[fusion-users] Nested JxSplitters which don't want to work
kde
kdelcroix at celsius-tech.com
Fri Dec 12 06:56:17 EST 2008
Hi everybody,
I have a blocking problem with Jx and its Splitters.
I want the split horizontaly the page in 2 parts and split the second parts
verticaly in 2.
But when I load this simpliest code (this html file is wel located in a
fusion template folder with all required xml/css/images (I use a copy of
"Slate")), I see only the "Si" DIV (the green one).
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN"
"http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<title>Test</title>
<meta http-equiv="Content-type" content="text/html; charset=utf-8">
<script type="text/javascript" src="../../../lib/fusion.js"></script>
<script type="text/javascript">
var main;
window.onload = function() {
main = new Jx.Layout('AppContainer', {left: 0, right: 0, top: 2, bottom:
0});
var sa1 = new Jx.Layout('SplitterArea', {left: 2, right: 2, top: 2,
bottom: 2});
var si = new Jx.Layout('Si', {});
var sa2 = new Jx.Layout('SplitterArea2', {});
var ma = new Jx.Layout('Ma', {});
var de = new Jx.Layout('De', {});
/* SPLITTER 1 */
var splitter = new Jx.Splitter('SplitterArea',
{splitInto:2,
elements: [$('Si'), $('SplitterArea2')],
layout:'horizontal',
containerOptions: [{width: 200}, null]
/* SPLITTER 2 */
var splitter2 = new Jx.Splitter('SplitterArea2',
{splitInto:2,
elements:[$('Ma'), $('De')],
layout:'vertical',
containerOptions: [{height: 200}, null]
main.resize();
</script>
<style type="text/css">
@import url(css/jxskin-border.css);
@import url(css/dialog_forms.css);
@import url(css/slate_fusion.css);
</style>
<!--[if IE 7]>
<style>
@import url(css/slate_ie7.css);
</style>
<![endif]-->
</head>
<body>
<div id="AppContainer">
<div id="SplitterArea">
<div id="Si" style="BACKGROUND-COLOR: green;">
</div>
<div id="SplitterArea2">
<div id="Ma" style="BACKGROUND-COLOR: red;">
</div>
<div id="De" style="BACKGROUND-COLOR: blue;">
</div>
</div>
</div>
</div>
</body>
</html>
What is wrong in this code?
Thanks in advance for your suggestion
View this message in context: http://n2.nabble.com/Nested-JxSplitters-which-don%27t-want-to-work-tp1647461p1647461.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users
