[fusion-users] Nested JxSplitters which don't want to work
kde
kdelcroix at celsius-tech.com
Fri Dec 12 11:07:30 EST 2008
Thanks Paul. Now I can see the second DIV (the red one) but not the third DIV
(the blue one).
I tried with several sizes but I can't make it work. The third DIV is too
little to be visible. It seems that the second DIV use all the heigh of the
window (it is what I see when I inspect the DOM tree of the page)
PS: I'm using Firefox 3
Paul Spencer-2 wrote:
> Hi - you need to join the list if you want to post questions otherwise.
> I just copied and pasted your code into an HTML file and loaded it and
> I see a green rectangle covering the left half of the viewport and a
> red rectangle covering the top right quarter and a blue rectangle
> covering the bottom right. However, this is not exactly what the code
> is asking for. The problem is that the splitters manage the content
> areas but you are also creating Jx.Layout objects to manage the
> content areas, so there is a confict.
> Removing the extra Jx.Layout and the default options, the code should
> look like:
> <script type="text/javascript">
> var main;
> window.onload = function() {
> main = new Jx.Layout('AppContainer', {
> top: 2
> var sa1 = new Jx.Layout('SplitterArea', {
> left: 2,
> right: 2,
> top: 2,
> bottom: 2
> /* SPLITTER 1 */
> var splitter = new Jx.Splitter('SplitterArea', {
> elements: [$('Si'), $('SplitterArea2')],
> containerOptions: [{width: 200}, null]
> /* SPLITTER 2 */
> var splitter2 = new Jx.Splitter('SplitterArea2',{
> elements:[$('Ma'), $('De')],
> layout:'vertical',
> containerOptions: [{height: 200}, null]
> main.resize();
> </script>
> Cheers
> Paul
> On 12-Dec-08, at 6:56 AM, kde wrote:
>> Hi everybody,
>> I have a blocking problem with Jx and its Splitters.
>> I want the split horizontaly the page in 2 parts and split the
>> second parts
>> verticaly in 2.
>> But when I load this simpliest code (this html file is wel located
>> in a
>> fusion template folder with all required xml/css/images (I use a
>> copy of
>> "Slate")), I see only the "Si" DIV (the green one).
>> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN"
>> "http://www.w3.org/TR/html4/strict.dtd">
>> <html>
>> <head>
>> <title>Test</title>
>> <meta http-equiv="Content-type" content="text/html; charset=utf-8">
>> <script type="text/javascript" src="../../../lib/fusion.js"></script>
>> var main;
>> main = new Jx.Layout('AppContainer', {left: 0, right: 0, top: 2,
>> bottom:
>> 0});
>> var sa1 = new Jx.Layout('SplitterArea', {left: 2, right: 2, top: 2,
>> bottom: 2});
>> var si = new Jx.Layout('Si', {});
>> var sa2 = new Jx.Layout('SplitterArea2', {});
>> var ma = new Jx.Layout('Ma', {});
>> var de = new Jx.Layout('De', {});
>> /* SPLITTER 1 */
>> {splitInto:2,
>> layout:'horizontal',
>> /* SPLITTER 2 */
>> {splitInto:2,
>> layout:'vertical',
>> main.resize();
>> </script>
>> <style type="text/css">
>> @import url(css/jxskin-border.css);
>> @import url(css/dialog_forms.css);
>> @import url(css/slate_fusion.css);
>> </style>
>> <!--[if IE 7]>
>> <style>
>> @import url(css/slate_ie7.css);
>> </style>
>> <![endif]-->
>> </head>
>> <body>
>> <div id="AppContainer">
>> <div id="SplitterArea">
>> <div id="Si" style="BACKGROUND-COLOR: green;">
>> </div>
>> <div id="SplitterArea2">
>> <div id="Ma" style="BACKGROUND-COLOR: red;">
>> </div>
>> <div id="De" style="BACKGROUND-COLOR: blue;">
>> </div>
>> </div>
>> </div>
>> </div>
>> </body>
>> </html>
>> What is wrong in this code?
>> Thanks in advance for your suggestion
>> View this message in context:
>> http://n2.nabble.com/Nested-JxSplitters-which-don%27t-want-to-work-tp1647461p1647461.html
>> Sent from the Fusion Users mailing list archive at Nabble.com.
>> fusion-users mailing list
>> fusion-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
> Paul Spencer
> Chief Technology Officer
> DM Solutions Group Inc
> http://research.dmsolutions.ca/
View this message in context: http://n2.nabble.com/Nested-JxSplitters-which-don%27t-want-to-work-tp1647461p1648372.html
More information about the fusion-users
