[fusion-users] Fusion + MapServer Function/Look Like MapGuide
Paul Spencer pspencer at dmsolutions.ca
Tue Jul 15 08:07:31 EDT 2008
Hi Tim,
you can get a Fusion application to look essentially like that
application using mapserver.  The tiling capability on the client side
is implemented by OpenLayers, so there is nothing magically mapguide
about it.  However, there is no support in the ApplicationDefinition
to let you define a tiled mapserver layer.  We are working on
supporting all the OpenLayers layer types through the
ApplicationDefinition for the 1.1 release but this work has not yet
been done.
Even when the necessary hooks in Fusion are available, you will still
need something on the server side to generate the tiles.  You can use
mapserver to do this directly, but it is pretty inefficient since
mapserver will draw the same tile over and over again.  What you need
is something that will cache tiles for you and serve them from the
cache if available.  For this, we will be recommending either the
kaMap's tile.php or TileCache.
Cheers
Paul
On 14-Jul-08, at 4:22 PM, Nolte, Tim wrote:
> OK, I know this is probably wishful thinking. AS I've looked at the
> MapGuide live app gallery. And specifically the following demo:
> http://data.mapguide.com/mapguide/phpviewersample/ajaxviewersample.php
> I would like to get Fusion (1.0.6) functioning and looking like that
> demo but using UMN MapServer. Is this even possible? Something I'm
> also
> wondering about is the Tiled AJAX sample. Is the tiling something
> specific and built in to MapGuide? I'm assuming the tiling is
> something
> on the server side and nothing to do with Fusion?
> - Tim
> Timothy J Nolte - tnolte at ilpcs.com
> Network Planning Engineer
> iPCS Wireless, Inc.
> 4717 Broadmoor Ave, Suite G
> Kentwood, MI 49512
> Office: 616-656-5163
> PCS:    616-706-2438
> Fax:    616-554-6484
> Web: www.ipcswirelessinc.com
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://www.dmsolutions.ca/
More information about the fusion-users mailing list
