[fusion-users] Fusion Questions
Paul Spencer
pspencer at dmsolutions.ca
Tue Jul 15 18:36:23 EDT 2008
* The max scale of the navigator widget should be calculated from the
extent defined in the map file. But the navigator is currently poorly
implemented so it is quite possibly not working or difficult to work
with.
* you should be able to use css to reposition the navigator
* I don't think you can set independent units for widgets but if you
can, then you would add <Units>meters</Units> (with the appropriate
unit) to the widget's <Extension> in the ApplicationDefinition.xml
Cheers
Paul
On 15-Jul-08, at 4:39 PM, Nolte, Tim wrote:
> Have a few questions:
> 1. How do you changing the max scale/zoom of the Navigator widget?
> 2. How do you set the navigator to be on the right side of the map by
> default?
> 3. How do you set different independent units for the CursorPosition &
> ViewSize widgets?
> Thanks!
> - Tim
> Timothy J Nolte - tnolte at ilpcs.com
> Network Planning Engineer
> iPCS Wireless, Inc.
> 4717 Broadmoor Ave, Suite G
> Kentwood, MI 49512
> Office: 616-656-5163
> PCS: 616-706-2438
> Fax: 616-554-6484
> Web: www.ipcswirelessinc.com
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://www.dmsolutions.ca/
More information about the fusion-users
