[fusion-users] Tr : Request for DMSG Fusion (MapServer) details
Yewondwossen Assefa
yassefa at dmsolutions.ca
Tue Mar 18 09:26:21 EDT 2008
Note also that a demo application using fusion 1.0.3 is available
through the osgeo4w installer at
http://wiki.osgeo.org/wiki/OSGeo_Win32_Installer
You need to use the advanced install and the fusion package is available
in the Web_application section.
Note that the installer is still in development but functional and
future versions of fusion release will be available through the same
mechanism.
Best Regards,
Paul Spencer wrote:
> Hi Maher,
> you need to join the fusion users mailing list to be able post
> (http://lists.osgeo.org/mailman/listinfo/fusion-users). I recommend it :)
> Fusion now has its own home separate from MapGuide OS at:
> http://trac.osgeo.org/fusion
> The version of fusion that you can get from that site (and associated
> SVN) work with MapServer. There is not a lot documented about working
> with MapServer yet, but it does work well with MapServer and is stable.
> We are looking for brave people to get started, ask questions and help
> with documenting it :)
> The basic things to do to get it working with MapServer are to
> * edit the config.json file and make sure that it has the right settings
> * create a <Map> tag in the ApplicationDefinition with
> <Type>MapServer</Type> and put the full path to the mapfile in the
> <Extension><MapFile></MapFile></Extension> block of the <Map>
> <Map>
> <Extension>
> <MapFile>/path/to/map/file</MapFile>
> </Extension>
> </Map>
> You will also want to make sure that your PHP has a setting for
> session.save_path in php.ini.
> Cheers
> Paul
> On 18-Mar-08, at 3:45 AM, Maher askri wrote:
>> Hi,
>> I'm a Tunisian student developing a web mapping application based on
>> MapServer (version 5.0).
>> I want to integrate DMSG Fusion in my application in order to enhance
>> it, but the problem is that i found only the version that works with
>> MapGuide (on
>> http://download.osgeo.org/mapguide/releases/fusion-preview/fusion-mapguide-1.0-preview.zip)
>> I read on your site (http://www.dmsolutions.ca/technology/fusion.html)
>> that MapServer is one of the supported mapping engines for Fusion.
>> so i'll be really grathefull to send me a link to download your Fusion
>> framework, or to let me know how it's possible to get it.
>> i have one more question: does the current Fusion version (1.0.3)
>> support MapServer ? if yes, is it stable at the moment ?
>> yours,
>> Envoyé avec Yahoo! Mail.
>> La boite email la plus appreciée au monde.
>> fusion-users mailing list
>> fusion-users at lists.osgeo.org
> Paul Spencer
> Chief Technology Officer
> DM Solutions Group Inc
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
More information about the fusion-users
