[fusion-users] Implementing Fusios
Warren M
warren.medernach at imaginit.ca
Fri May 2 13:24:25 EDT 2008
Thanks Paul!
So I guess what I'm looking to do is what you described below:
So you can create a single 'template' and start fusion by pointing to
one of many ApplicationDefinitions thus controlling the functionality
of the application while preserving the same basic layout and look &
feel between them.
Essentially, I'm going to have my MG data structured as in the graphic
below, and I want to have a single template/wrapper to load the appropriate
Map based on some parameter that is passed.
http://www.nabble.com/file/p17024034/MG_AppStructure.png
Based on your description then, I could have ApplicationDefintion_App1.xml,
ApplicationDefintion_App2.xml, ApplicationDefintion_App3.xml, etcc. all
calling a single fusion template. Obviously I need to learn more about how
Fusion works ;-) I've got some work to do...
Thanks again Paul.
Warren
View this message in context: http://www.nabble.com/Implementing-Fusios-tp16995020p17024034.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users
