[fusion-users] Fusion release 1.0.5
Zac Spitzer
zac.spitzer at gmail.com
Sat May 10 00:26:34 EDT 2008
> None of the fusion maps in the Sheboygan Sample are tiled which I
> think should be addressed as this is everyone's default test set. I
> will file a ticket on under the mapguide trac for this ( the server is
> down at the moment )
http://trac.osgeo.org/mapguide/ticket/550
> I created a ticket for the report server connection error
> http://trac.osgeo.org/fusion/ticket/61
> z
> On Sat, May 10, 2008 at 1:03 AM, Mike Adair <madair at dmsolutions.ca> wrote:
>> Zac,
>> Thanks for testing. Perhaps we should put in place some sort of RC process
>> to shake out bugs like this.
>> I've got a fix for the StatusBar problem in Fusion, but getting that out
>> there would require another release. I'm not sure why that doesn't occur
>> with the standard template, but the solution is to force a resize on
>> Container elements once they get created.
>> For issue #2, with the slate template I'm seeing 87.7045, 43.7656 at the
>> intersection of Park Ave and N 3rd St. which I think is the correct
>> coordinates. Are you only getting 2 digits of precision? Make sure that
>> the CursorPosition widget has <Precision>4</Precision> in it's
>> <Extension> element. If that's not the case can you point me to a URL that
>> shows the incorrect locations?
>> For the MgServer crashing issue, that wasn't addressed in the release, but
>> it would be good to do something about that in a future release. Can you
>> enter a trac ticket for it please?
>> Thanks again for the reports.
>> Mike
>> Zac Spitzer wrote:
>>> ok, i did that. I renamed the folder, installed 1.0.5 and then copied
>>> across the mg templates
>>> from the old fusion/templates/mapguide directory
>>> It works ok, but the status bar elements are all on top of each other
>>> also, my mgserver had crashed (again) and fusion just sits there doing
>>> nothing without any
>>> feedback that there was no response from mapguide
>>> http://trac.osgeo.org/fusion/ticket/2 is still not working, i getting
>>> 88 44 instead of 87 43
>>> z
>>> On Fri, May 9, 2008 at 11:43 AM, Jason Birch <Jason.Birch at nanaimo.ca>
>>> wrote:
>>>> Rename it / back it up.
>>>> You'll need to copy the MapGuide templates from the distributed fusion
>>>> folder into the new fusion folder after installing. I haven't had a chance
>>>> to test this release yet :(
>>>> Jason
>>>> ________________________________
>>>> From: Zac Spitzer
>>>> Subject: Re: [fusion-users] Fusion release 1.0.5
>>>> To install on an existing mapgudie instance, do we overwrite the
>>>> fusion folder or should i delete it first?
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
More information about the fusion-users
