[fusion-users] Widget Functions.
Tómas Guðmundsson tomas at snertill.is
Wed May 14 10:36:48 EDT 2008
I'm so sorry guys, but none of these methods work for me to load an external Javascript. Maybe the dirty hack:
 Document.write('<script type="text/javascript" language="javascript" src="myCoolWidget.js"></script>'); ?
Rgds
tomas
-----Original Message-----
From: fusion-users-bounces at lists.osgeo.org [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Alan Boudreault
Sent: 14. maí 2008 14:33
To: fusion-users at lists.osgeo.org
Subject: Re: [fusion-users] Widget Functions.
I just checked something... and i think you use the Fusion.require
method in your sneRefreshMap definition file.
ie: Fusion.require(widgets/myRequiredWidget.js');
This will avoid to add extra unuseful information in the
ApplicationDefinition.xml.
Regards,
Alan
Tómas Guðmundsson wrote:
> I tried what you guys said. Here is the block I added. Note my widget is called sneBlockUI.
> ApplicationDefinition.xml:
>  * Trying to load extra javascripts
>  * with xml here. Required by fusion.
>  <Container xsi:type="UiItemContainerType">
>   <Name>sneBlockUI</Name>
>   <Type>Block UI</Type>
>    <Item xsi:type="WidgetItemType">
>      <Function>Widget</Function>
>      <Widget>sneBlockUI</Widget>
>    </Item>
>  </Container>
> index.html:
> <div id="sneBlockUI"></div>
> Do I need to add the widget (xml) definition for sneBlockUI as well ?
> From: fusion-users-bounces at lists.osgeo.org [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Mike Adair
> Sent: 14. maí 2008 13:52
> To: Alan Boudreault
> Cc: fusion-users at lists.osgeo.org
> Also, widgets must be associated with a DOM element to be instantiated.
> This can be either through a <Container><Item> element, or simply
> through a <div id='widgetName'> element in the page (I think this
> works).  You can try putting a breakpoint in the widget constructor to
> see if it ever gets instantiated.
> Mike
> Alan Boudreault wrote:
>> Where is defined you class sneBlockUI ? Can you check with firebug if
>> the file you defined this class is well loaded ? Fusion does'nt load
>> all the "TheWidget.js" files by default,  only those that are
>> required. (Those defined in the ApplicationDefinition.xml)
>> Regards,
>> Alan
>>> Yeah,
>>> Here are the errors I get via firebug.
>>> Fusion.Widget.sneBlockUI is not a constructor
>>>  - this.blocker = new Fusion.Widget.sneBlockUI();  ---
>>> sneRefreshMap.js (line 8)
>>> blockUI is not defined
>>>  - blockUI(); --- sneRefreshMap.js (line 16)
>>> What I am aiming for is this blocking of the ui while the map is
>>> rendering so maybe I should just modify the Map.js ?
>>> However here is the code.
>>> Fusion.Widget.sneRefreshMap = Class.create();
>>> Fusion.Widget.sneRefreshMap.prototype =  {
>>>     initialize : function(widgetTag) {
>>>         //console.log('RefreshMap.initialize');
>>>         Object.inheritFrom(this, Fusion.Widget.prototype, [widgetTag,
>>> true]);
>>>         Object.inheritFrom(this, Fusion.Tool.ButtonBase.prototype, []);
>>>         this.dialog = null;
>>>      * execute function.
>>>     execute : function() {
>>>         var map = this.getMap();
>>>         blockUI();
>>>         map.redraw();                   },
>>>         blockUI : function() {
>>>         if (!this.dialog) {
>>>         var size = Element.getPageDimensions();
>>>         var o = {
>>>             title: OpenLayers.String.translate('Loading'),
>>>             imageBaseUrl: this.imageBaseUrl,
>>>             width: 150,
>>>             height: 85,
>>>             resizeable: false,
>>>             top: (size.height-200)/2,
>>>             left: (size.width-320)/2,
>>>     this.dialog = new Jx.Dialog(o);
>>>         this.dialog.open();            }
>>> From: Paul Spencer [mailto:pspencer at dmsolutions.ca] Sent: 14. maí
>>> 2008 11:25
>>> To: Tómas Guðmundsson
>>> I'm not sure about the first error, can you send code for us to look at?
>>> For the second, try:
>>> var myObject = new Fusion.Widget.MyNewWidget();
>>> Paul
>>> On 14-May-08, at 5:57 AM, Tómas Guðmundsson wrote:
>>>> Hi all.
>>>> I have been wondering about a very strange "bug" but then again
>>>> this  might be something that you don't notice until you've told
>>>> everybody  about it and feel like a complete idiot.
>>>> I'm trying to create a code that extends the refresh widget by
>>>> opening up a ui-blocking page like the Print widget does. However,
>>>> if I just use the pure code from Print.js, like copy/paste. Firebug
>>>> gives me an error that the function can not be found. Totally
>>>> cryptic to me. It is defined exactly like the Print.js widget, do I
>>>> need to define my functions somewhere else ?
>>>> Also, if I have created a seperate widget that I want to use just
>>>> like a new class in a conventional programming, like so.
>>>> var myObject = new MyNewWidget();
>>>> Do I need to call Fusion.Class or something ?
>>>> Thanks
>>>> Tomas
>>>> _______________________________________________
>>>> fusion-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>>>     Paul SpencerTómas Guðmundsson <tomas at snertill.is>
>>>     Chief Technology Officer
>>>     DM Solutions Group Inc
>>>     http://www.dmsolutions.ca/
Alan Boudreault
Mapgears
http://www.mapgears.com
More information about the fusion-users mailing list
