[fusion-users] Tiling and <SingleTile>
Andrew Parker
andrew at source3.com
Thu Nov 6 21:44:22 EST 2008
Paul:
I tried a few days ago setting <SingleTile> true/false </SingleTile> in
the ApplicationDefinition.xml to "true" then to "false". Currently, I
have it set to "false".
If you visit "http://pitrule.source3.com" you will notice that in the
status bar of FireFox it states "Transferring data from
pitrule.source3.com", which does not go away. If I set <SingleTile> to
"true" the Firefox status bar states "Done" but the Firefox loading icon
(upper right) continues to turn. Do I:
1. have a memory leak?
2. need to ask HostGIS to check if the server is getting hit hard while
the map is open?
3. not worry about it, it is just a bug?
Thanks.
~Andrew
Paul Spencer wrote:
> Hi Andrew,
> you might be able to get it to tile your requests by adding
> <singleTile>false</singleTile> to the <Map> or <Map><Extension> tag in
> your application definition, but that won't cache the tiles so it will
> be hard on the server. Then again, I haven't really tried doing this
> so the MapServer stuff in Fusion may ignore singleTile.
> We are adding support for all OpenLayers layer types soon and then you
> can specify a WMS layer or TMS layer and point it to a TileCache
> instance that uses MapServer to generate the map tiles. It should be
> in SVN in a week or two and be officially supported in the 2.0 release
> that should be out before the end of the year.
> Cheers
> Paul
> On 6-Nov-08, at 9:34 AM, Andrew Parker wrote:
>> Stuart:
>> I do not have an answer for you. But I am starting work on a similar
>> problem today and would like to have a solution by next Wednesday.
>> Below is a brief description of what I am trying to do. FYI: I am
>> not a developer so I have no idea how to go about doing this; but I
>> have a programmer to turn to for help.
>> I am running Fusion for MapServer. I have not installed Mapguide
>> OS. I want to enable tiling for this site:
>> http://pitrule.source3.com. And change my "Base Map" group in the
>> Legend from checkboxes (overlay) to radio buttons (basemap).
>> All the threads I have seen talks about using MapGuide, but I have
>> not found any howto's or suggestions to implement tiling for Fusion
>> for MapServer. I am clearly not understanding something.
>> Lastly, when I figure out how to do this, I will be creating a
>> howto. In addition, I will create a new topic for my progress as I
>> do not want to impose on your thread.
>> Good luck and if I see a solution for your issue I will let you know.
>> ~ Andrew
>> gingerbbm wrote:
>>> Right, well I found this thread:
>>> http://n2.nabble.com/Fusion---Base-layers-questions...-td1303997.html
>>> So again I need to find a workaround...
>> fusion-users mailing list
>> fusion-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
> Paul Spencer
> Chief Technology Officer
> DM Solutions Group Inc
> http://research.dmsolutions.ca/
More information about the fusion-users
