[fusion-users] Multiple versions of prototype.js
Paul Spencer
pspencer at dmsolutions.ca
Fri Nov 14 07:17:49 EST 2008
The scriptaculous stuff is directly embedded in jx_combined.js, so you
don't need to change that.
Selenium is a testing framework that is not used at runtime (or
actually ever ;)). Ignore it.
OpenLayers safely incorporates portions of the Prototype code, it used
to be based on Prototype but they eventually pulled it out and just
kept portions of the code. You *should* be able to leave OpenLayers
as-is and it should not collide with your new Prototype.
Cheers
Paul
On 14-Nov-08, at 7:00 AM, gingerbbm wrote:
> Paul Spencer-2 wrote:
>> Or you could just remove those lines from jx_combined.js load your
>> own
>> Prototype/Scriptaculous first.
> I quite like the sound of that.
> The thing is, when I implemented my search/replace solution to
> rename the
> Prototype object, I used a brute force approach which impacted the
> following
> files:
> http://n2.nabble.com/file/n1498158/fusion_files_containing_prototype.png
> Is jx_combined.js really all I'd need to change?
> View this message in context: http://n2.nabble.com/Multiple-versions-of-prototype.js-tp1494625p1498158.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://research.dmsolutions.ca/
More information about the fusion-users
