[fusion-users] Fusion default DisplayUnit
Andrew Parker
andrew at source3.com
Mon Nov 24 08:51:29 EST 2008
I do not now if this is the best way, but this is how I changed the units:
In ApplicationDefinition.xml search for "units" and changed all value to
miles (or whatever unit you want). When you search for "units" you will
either find <Unit> tags and <DisplayUnits> tags. You can see my changes
at http://216.93.173.156/demo.
Look at the Fusion API for available units. For example, the options
for the measure toolbar are listed at
http://trac.osgeo.org/fusion/wiki/Widgets/Measure.
I also changed the units of the coordinate position to Lat/Long. In the
ApplicationDefinition.xml, I changed the <Template> tag to as follows:
<!-- STATUS POSITION -->
<Widget xsi:type="WidgetType">
<Name>StatusCoords</Name>
<Type>CursorPosition</Type>
<StatusItem/>
<Extension xsi:type="CustomContentType">
<Template>Lat/Long: {y}, {x}</Template>
<Precision>4</Precision>
<EmptyText>&nbsp;</EmptyText>
</Extension>
</Widget>
As for the scale, I am not sure. Are you using MapServer? If so, maybe
you can set the scale in MapServer?
Andrew
Suhaimi AK wrote:
> Hi,
> I'm using fusion and customize ApplicationDefinition.xml using the maroon
> template example. I'm creating my map using maestro.
> My problem is, my map display units is start in metrics. So do my scale with
> scale 1:104857600104.4932 for example. How can i change my default units and
> scale to 1:50000 or 1:100000.
> Thank you in advance.
> Regards.
> Suhaimi AK
More information about the fusion-users
