[fusion-users] Legend widget is not updating correctly
Rodolfo Moreno rmoreno at voxiva.com
Wed Oct 15 12:23:29 EDT 2008
Hi Paul,
Could I put a ticket for this issue, in order to know when it will be
solved?
Thanks
Paul Spencer-2 wrote:
> Good.  I suppose we can add a random string to the URL that requests
> legend images to make caching not happen, although this may cause some
> things to be less efficient.  We must proceed with caution.
> Cheers
> Paul
> On 14-Oct-08, at 11:15 AM, Rodolfo Moreno wrote:
>> Hi Paul,
>> I am using reloadMap because is the unique way for update the legend
>> programatically.
>> What it happening is the second, the browser is caching the legend
>> images
>> from previos theme. I have cheked it and after of deleting the cache
>> FUSION
>> is painting correctly the legend widget either in IE and FF.
>> Maybe it to be an issue since the map widget doesn't have this
>> problem with
>> the cache.
>> Regards,
>>> Rodolfo,
>>> I don't think the legend widget will update correctly unless you call
>>> the reloadMap method of the map widget after changing the theming of
>>> the layer.  It is also possible (but less likely in this case) that
>>> the browser is caching the legend images from the previous theme.
>>> Cheers
>>> Paul
>>> On 13-Oct-08, at 1:55 PM, Rodolfo Moreno wrote:
>>>> Hi all,
>>>> Here are the steps in order to replicate the issue:
>>>> 1. To create a new session layer (programatically)
>>>> 2. Next, user themes the new session layer (according to his/her
>>>> preference)
>>>> then, the map widget is updated correctly however the legend
>>>> widget is
>>>> updated incorrectly (view the attached image).
>>>> The attached image shows the layer reddesague(rd) themed with
>>>> different
>>>> color that the legend widget.
>>>> The ranks shows in the legend widget are correct however the colors
>>>> are
>>>> wrongs.
>>>> Plataform: WINDOW, IIS 6, MAPGUIDE OS 2.0.1, .NET Enviroment
>>>> Is this issue known?
>>>> http://n2.nabble.com/file/n1329703/VentanillaFUSIONissue.JPG
>>>> Rodolfo Moreno
>>>> CivilEng
>>>> View this message in context:
>>>> http://n2.nabble.com/Legend-widget-is-not-updating-correctly-tp1329703p1329703.html
>>>> Sent from the Fusion Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> fusion-users mailing list
>>>> fusion-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>>>    Paul Spencer
>>>    Chief Technology Officer
>>>    DM Solutions Group Inc
>>>    http://www.dmsolutions.ca/
>> Rodolfo Moreno
>> CivilEng
>> http://n2.nabble.com/Legend-widget-is-not-updating-correctly-tp1329703p1332983.html
>     Paul Spencer
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/Legend-widget-is-not-updating-correctly-tp1329703p1337504.html
More information about the fusion-users mailing list
