[fusion-users] Demo works in HostLinux but not Ubuntu 8.04 Server
Andrew Parker
andrew at source3.com
Tue Oct 28 12:17:11 EDT 2008
Ok, I must be missing the obvious as I still cannot see the demo. I
made the changes per Paul D's suggestions (see below).
This is what I did:
1. verified that the ServerRoot is "/etc/apache2"
2. verified that the DocumentRoot is set to "/var/www"
3. verified that "/etc/ apache2/tmp" exists and permissions set to 777
4. verfied that "/var/www/tmp/ms_tmp" exists and permissions set to 777
5. Modified Fusions' config.json as shown below
5. Restarted apache2
current configuration of config.json:
/* This is the fusion configuration file. Adjust as necessary. */
/* The general section contains settings that are general to
fusion as a whole. */
"general": {
/* PHP is the default and only script language supported.
Don"t change this. */
"scriptLanguage": "php",
/* A directory on this system that fusion can use for
temporary files. */
"temporaryDirectory": "/etc/apache2/tmp"
/* The MapGuide section is required if you are installing
fusion for MapGuide. */
"mapguide": {
/* The WebTierURL is the url to mapguide, it should start
with http and end with /mapguide. If you have installed
fusion inside the www directory of MapGuide, then you can
leave this empty as it will be automatically calculated. */
"webTierUrl": ""
/* The MapServer section is required if you are installing fusion
for MapServer. */
"mapserver": {
/* The URL of the mapserver CGI that you want to use. */
"cgi": "/cgi-bin/mapserv",
/* The file system path to where mapserver should put
web-accessible temporary images. */
"imagePath": "/var/www/tmp/ms_tmp",
/* The URL to the image path configured above. */
"imageUrl": "http://localhost/tmp/ms_tmp",
web-accessible temporary legend images. */
"legendIconCacheDir":"/var/www/tmp/ms_tmp"
Any other setting/configurations I should check?
In a twisted sort of way, I love this debugging stuff!
~andrew
Paul Deschamps wrote:
> Your problem is right there in your config.
> temporary files. */
> "temporaryDirectory": "/tmp"
> should be:
> also look at the image path and imageURL values.
> "imagePath": "/tmp/ms_tmp",
> "legendIconCacheDir":"/tmp/ms_
> tmp"
> Cheers
> Paul D
> On Tue, Oct 28, 2008 at 9:51 AM, Andrew Parker <andrew at source3.com
> <mailto:andrew at source3.com>> wrote:
> I got the Fusion Demo working as discussed in
> http://n2.nabble.com/Mapfile-not-displaying-in-Fusion-for-MapServer-td1379147.html.
> The working Demo uses HostLinux offered by HostGIS.
> When I try to view the Demo using Ubuntu 8.04 server (and Ubuntu
> 7.10) I can only see the html layout, no layer tree or toolbars.
> However, I can see the mapfile using
> http://localhost/cgi-bin/mapserv?mode=map&map=/var/www/chp2/hello.map
> <http://localhost/cgi-bin/mapserv?mode=map&map=/var/www/chp2/hello.map>.
> I think the problem is where Fusion and MapServer is storing the
> temporary files. So I started playing around with the paths. The
> config.json file is as follows:
> "general": {
> temporary files. */
> "mapguide": {
> "webTierUrl": ""
> for MapServer. */
> "mapserver": {
> "legendIconCacheDir":"/tmp/ms_tmp"
> The ServerRoot in apache2 is /etc/apache2. The apache2
> DocumentRoot is /var/www.
> Therefore, I created the directory tmp (/etc/apache2/tmp) and set
> permission to 777. Restarted apache2 and tested the demo. Same
> results. Looked in /etc/apache2/tmp and did not see any Fusion
> session files. I also create the /tmp/ms_tmp directories in
> /var/www and /var. No temp files were saved in these directories.
> Then I decided to change the SeverRoot to /var and /var/www to see
> what happens. Restarted apache2 and same results, only the html
> layout.
> Know I am out of ideas. Does anyone have an idea how to fix this.
> I really want to include how to get Fusion working in Ubuntu in
> my HowTo I am writing for grad school.
> Thank you very much.
> Andrew
> fusion-users mailing list
> fusion-users at lists.osgeo.org <mailto:fusion-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/fusion-users
> Paul Deschamps
> Applications Specialist
> DM Solutions Group Inc.
> Office: (613) 565-5056 x28
> pdeschamps at dmsolutions.ca <mailto:pdeschamps at dmsolutions.ca>
> http://www.dmsolutions.ca
> http://research.dmsolutions.ca
More information about the fusion-users
