[fusion-users] Map does not draw using a virtual host
Andrew Parker
andrew at source3.com
Wed Oct 29 11:56:52 EDT 2008
I have Fusion working on my server at HostGIS. When I access the demo
using http://216.93.173.156/demo/ the map renders. But when I use the
virtual host http://demo.source3.com I get an error and the map does not
draw. In Firebug, I see the error but cannot figure out what is causing
it.
HostGIS checked the server on their side and said everything is fine.
*** FROM HostGIS ***
Ah, I see in the error log a major clue:
[Tue Oct 28 12:31:48 2008] [error] [client 67.142.161.26] File does not
exist: /var/www/htdocs/demo/fusion, referer: http://demo.source3.com/
[Tue Oct 28 12:31:49 2008] [error] [client 67.142.161.26] File does not
Looks to me like you didn't fix an URL in your application: it's still
looking for /demo/fusion or something like that. Double check your URLs
and make sure they're all correct; the webserver is behaving properly.
*** END HostGIS ****
I am having the same problem with the template from
../fusion/template/mapserver/standard. When I access the template from
http://216.93.173.156/pitrule/ the map draws. When I access the
template from the virtual host http://pitrule.source3.com I get an
error. In Firebug I can see the cause of the error. But what is
causing it?
Thanks for helping me so much. Hopefully in a week or two I will have a
good grasp of Fusion and stop asking so many questions!
More information about the fusion-users
