[fusion-users] Fusion Widget frame
Nolte, Tim
Tim.Nolte at ipcswirelessinc.com
Mon Dec 14 14:25:06 EST 2009
Actually, the Task Pane is by default created as an iFrame.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
Sprint Nextel
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS: 616-706-2438
Fax: 616-554-6484
-----Original Message-----
From: fusion-users-bounces at lists.osgeo.org [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Mark Pendergraft
Sent: Monday, December 14, 2009 12:55 PM
To: fusion-users at lists.osgeo.org
Subject: Re: [fusion-users] Fusion Widget frame
I don’t believe Fusion uses frames. The JX library is how fusion pages are
laid out at runtime. It's a UI framework, more information on it can be
found here: http://www.jxlib.org/
-Mark P.
Twi wrote:
> Twi wrote:
>> ThanK you.
>> So, I use Jx Library to move the widget in another frame ? I use a
>> different frame
>> to receive the results of the selection. The index.html page must include
>> the map and the legend only. The widgets are placed in different frames.
>> :confused:
View this message in context: http://n2.nabble.com/Fusion-Widget-frame-tp4150340p4165718.html
Sent from the Fusion Users mailing list archive at Nabble.com.
fusion-users mailing list
http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users
