[fusion-users] Fusion 2 is not rendering the page
Paul Spencer
pspencer at dmsolutions.ca
Tue Feb 24 15:59:18 EST 2009
you need to set the correct MapId in the MapWidget tag (map_1 from
looking at your xml).
Hopefully that is all ...
Paul
On 24-Feb-09, at 3:44 PM, Eduardo Kanegae wrote:
> hi,
> I've successfully instaled Fusion 1.1.1 (
> http://www.webmapit.com.br/viewmap/f1/templates/mapserver/standard/ )
> But Fusion 2 is not rendering the page.After pointing to the address
> http://www.webmapit.com.br/viewmap/f2/templates/mapserver/standard/
> I can even see its page source but page is blank displayed ( IE,
> FireFox or Chrome ).
> My php_errors.log is showing:
> [24-Feb-2009 17:51:39] PHP Warning: DOMDocument::loadXML() [<a
> href='function.DOMDocument-loadXML'>function.DOMDocument-loadXML</a>]:
> Specification mandate value for attribute typ in Entity, line: 1 in
> /myserver/f2/common/php/Xml2JSON.php on line 65
> attributes construct error in Entity, line: 1 in
> Couldn't find end of Start Tag Extension line 1 in Entity, line: 1 in
> Premature end of data in tag Widget line 1 in Entity, line: 1 in
> Premature end of data in tag WidgetSet line 1 in Entity, line: 1 in
> Premature end of data in tag ApplicationDefinition line 1 in Entity,
> line: 1 in /myserver/f2/common/php/Xml2JSON.php on line 65
> appDefinition is at
> http://www.webmapit.com.br/viewmap/f2/templates/mapserver/standard/ApplicationDefinition.xml
> Is there any additional setting before running fusion 2?
> best regards
> Eduardo Kanegae
> http://anthologis.com
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://research.dmsolutions.ca/
More information about the fusion-users
