[fusion-users] RE: Getting started with Fusion and MGOS
Praveen Rajendra Babu
prbabu at openspatial.com.au
Mon Jan 5 20:11:42 EST 2009
Hi Paul,
Thanks for your response. When I installed the WSE(Web Server Extensions), I could see only the below paths:
"www\fusion\templates\mapguide\slate"
"www\fusion\templates\mapguide\aqua"
"www\fusion\templates\mapguide\limegold" etc...
So basically, I can access the Fusion template using the URL:
http://localhost/mapguide/fusion/templates/mapguide/slate/index.html
Basically, I could n't see any "samples" directory within the WSE directory tree.
But the fusion\docs\installation.html refer to them.
Also noted that Common.php file's defaultInstallDir, defaultExtensionDir variable
contents are:
$defaultInstallDir = dirname(__FILE__)."/../../../../../";
$defaultExtensionDir = realpath($defaultInstallDir . "webserverextensions/www/");
rather than the one mentioned in the "installation.html".
I believe it is more like updating the documentation.
Please let me know if I did not get your comments right.
Thanks and regards,
Praveen
Hi Praveen,
sorry I've been away for a couple of weeks and am just catching up. I
don't think there was a reply to this email.
There are a couple of ways to get a Fusion app running, probably the
simplest is just to point your web browser at
http://localhost:8008/mapguide/fusion/samples/mapguide/slate/
This will load the slate template and a default
ApplicationDefinition.xml file (that is stored outside the mapguide
repository in the same directory as the template).
If you have Studio you can create a new Flexible Web Layout and
preview it directly from Studio. Maestro may have support for
ApplicationDefinition.xml files and Fusion but I am not sure (I
haven't tried it in a while).
The main fusion web site is http://trac.osgeo.org/fusion
Cheers
Paul
On 22-Dec-08, at 8:28 PM, Praveen Rajendra Babu wrote:
> Hello,
> I have downloaded and installed
> MgWebServerExtensionsSetup-2.0.2.3011.exe along with MGOS
> 2.0.2.3011. I can get the sample Sheboygan dataset working with
> the .Net and PHP AJAX viewers. Now I want to use Fusion viewer to
> see the Sheboygan dataset. Any suggestions and links where I can get
> more info. on this?
> The ?fusion/docs/installation.html? is referring to index.html,
> redirect.php etc?, but could n?t find anything like that obviously.
> Also, what is the Fusion home-page for latest downloads,
> documentation etc?? Too many questions pending!
> Thanks for your time.
> Regards,
> Praveen
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://research.dmsolutions.ca/
End of fusion-users Digest, Vol 11, Issue 1
More information about the fusion-users
