[fusion-users] RE: Auto-authenticate when using Fusion Viewer
Chris Claydon
chris.claydon at autodesk.com
Wed Jan 7 18:11:23 EST 2009
I'm not sure off hand exactly what causes the first authentication prompt - probably the first call to get the flexible web layout definition from the MG repository. If the initial request is sent with no authentication parameters, MG will send a response indicating that it requires credentials, and I believe that's what causes the browser to prompt the user.
From: Praveen Rajendra Babu [mailto:prbabu at openspatial.com.au]
Sent: Wednesday, January 07, 2009 3:54 PM
To: Chris Claydon; fusion-users at lists.osgeo.org
Subject: RE: Auto-authenticate when using Fusion Viewer
Thanks Chris! Works sweet and fine! Can you please let me know which section of the code is bringing up the user authentication prompt
on the browser. The "fusion\MapGuide\php\Common.php" does n't seem to do so, atleast to my understanding.
Thanks again.
Regards,
Praveen
From: Chris Claydon [mailto:chris.claydon at autodesk.com]
Sent: Thursday, 8 January 2009 3:44 AM
To: Praveen Rajendra Babu; fusion-users at lists.osgeo.org
Ideally, the Fusion code would be updated to allow you to specify USERNAME and PASSWORD the same way that the AJAX Viewer does. Until that happens, there is a workaround...
Fusion allows you to authenticate with a session ID. Here's a simple php script that creates a session using the 'Anonymous' user and re-directs to the template of your choice...
<?php
$fusionMGpath = './MapGuide/php/';
include $fusionMGpath . 'Common.php';
$locale = GetDefaultLocale();
$appdef = "";
$template = "";
$session = $siteConnection->GetSite()->CreateSession();
GetRequestParameters();
$viewerSrc = 'templates/mapguide/' . $template . '/index.html';
$viewerSrc = $viewerSrc . '?APPLICATIONDEFINITION=' . $appdef;
$viewerSrc = $viewerSrc . '&SESSION=' . $session;
header( 'Location: ' . $viewerSrc ) ;
function GetParameters($params)
global $appdef, $template;
$appdef = $params['APPLICATIONDEFINITION'];
$template = $params['TEMPLATE'];
function GetRequestParameters()
if($_SERVER['REQUEST_METHOD'] == "POST")
GetParameters($_POST);
else
GetParameters($_GET);
Save this script in a file called something like FlexViewer.php, and drop it in the www/fusion folder in the MapGuide web tier. You can then link to it using a URL that includes the parameters APPLICATIONDEFINITION and TEMPLATE. E.g.
http://myserver/mapguide20xx/fusion/FlexViewer.php?APPLICATIONDEFINITION=Library%3a%2f%2fSheboyganSandbox.ApplicationDefinition&TEMPLATE=Slate
You should no longer need to authenticate.
Note that in MG 2010, the fusionMGpath parameter will change to './Layers/MapGuide/php/' but the rest of the script should still be fine.
Chris.
From: fusion-users-bounces at lists.osgeo.org [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Praveen Rajendra Babu
Sent: Tuesday, January 06, 2009 6:28 PM
To: fusion-users at lists.osgeo.org
Subject: [fusion-users] Auto-authenticate when using Fusion Viewer
Hello,
I am working to do auto-authentication when using any off the Fusion templates. Can anyone direct me on the code to look at?
I was able to figure out with .NET AJAX viewer(mapviewernet\mainframe.aspx) but could n't see something similar to that under "fusion" sub-directory.
Also, is there any code-level documentation one could look at to get a deeper understanding on Fusion's implementation?
Thanks again for your time. Appreciate it.
Regards,
Praveen
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20090107/79de4984/attachment-0001.html
More information about the fusion-users
