[fusion-users] MapGuide Ent 2010: Fusion and digitize error
Paul Spencer
pspencer at dmsolutions.ca
Tue Jul 14 10:13:33 EDT 2009
Its approximately the same version of that code as is with the current
MGOS 2.1 beta. I think your current work around is probably fine.
The architecture of this code is changing for the next release and
will make this problem a non-issue.
You can always replace (after making a backup!) fusion in a mapguide
release by just moving the current fusion folder and unzipping the new
fusion in its place. As fusion does not ship with the mapguide
templates by default, you will need to copy the contents of templates/
mapguide from the original fusion to the newly installed one. Not
sure what this does to any support agreements you have with ADSK for
MGE2010 though :)
Cheers
Paul
On 13-Jul-09, at 1:25 PM, Matteo wrote:
> Hi Paul,
> I have this code in my MapGuideViewerApi.js. I see that there is a
> beta
> version of fusion but I don't know how version I have. How I can get
> this
> info ( I work with MG Enterprise 2010)?
> Thanks
> Matteo
> Paul Spencer-2 wrote:
>> Ah I see the problem now. CanvasTool is designed as a mixin class
>> for
>> widgets to provide client-side rendering services. Each widget
>> provides a getMap method which is available to the CanvasTool
>> methods. When CanvasTool is used by the MapGuideViewerApi.js
>> methods,
>> it is created directly (not as a mixin for Widget) and hence has no
>> getMap() method.
>> In MapGuideViewerApi.js in fusion distributed with MGOS 2.1 beta
>> around line 176, there is this:
>> Fusion.Tool.Canvas.prototype.getMap = function() {
>> return Fusion.getWidgetById(mapWidgetId);
>> which should, theoretically, be doing the same thing you are doing by
>> modifying CanvasTool.js directly. Does the version you have include
>> this definition? If not, can you try adding the above to
>> MapGuideViewerApi.js (anywhere will do) and removing your change to
>> CanvasTool.js and see if it still works?
>> Cheers
>> Paul
>> On 3-Jul-09, at 3:05 AM, Matteo wrote:
>>> Hi Paul,
>>> I give the same error in IE and Firefox. The file CanvasTool.js
>>> don't
>>> have a getMap function so to resolve the problem I must add this
>>> function to
>>> the file
>>> getMap: function() {
>>> var map=this.oMap;
>>> if (typeof(map) == "undefined"){
>>> map=this.map;
>>> return map;
>>> Now works fine
>>> Regards Matteo
>>>> It seems like your template is using the single file, compressed
>>>> build
>>>> of Fusion ... which is singularly unhelpful for debugging problems
>>>> since the code is stripped down. You need to change the template's
>>>> index.html file to using fusion.js instead of fusionSF.js (or
>>>> whatever
>>>> it is) and then we might get some more helpful errors.
>>>> What web browser are you using? IE? Do you get the same error in
>>>> other browsers (i.e. Firefox)
>>>> Paul
>>>> On 2-Jul-09, at 8:27 AM, Matteo wrote:
>>>>> Hi,
>>>>> I try to develop an application with Fusion for draw some object.
>>>>> When I
>>>>> call the digitize function of MapGuideViewerApi.js (ex
>>>>> DigitizePolygon) I
>>>>> get an error on activateCanvas function at this line
>>>>> var C=this.getMap()
>>>>> Can you help me?
>>>>> Regards Matteo
>>>>> View this message in context:
>>>>> http://n2.nabble.com/MapGuide-Ent-2010%3A-Fusion-and-digitize-error-tp3194766p3194766.html
>>>>> Sent from the Fusion Users mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> fusion-users mailing list
>>>>> fusion-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>>>> Paul Spencer
>>>> Chief Technology Officer
>>>> DM Solutions Group Inc
>>>> http://research.dmsolutions.ca/
>>> http://n2.nabble.com/MapGuide-Ent-2010%3A-Fusion-and-digitize-error-tp3194766p3199859.html
>> Paul Spencer
> View this message in context: http://n2.nabble.com/MapGuide-Ent-2010%3A-Fusion-and-digitize-error-tp3194766p3251856.html
Paul Spencer
More information about the fusion-users
