[fusion-users] Startup widgets possible?
Jackie Ng
jumpinjackie at gmail.com
Fri Jul 24 01:15:55 EDT 2009
Hi Paul,
Yeah I was aware of technique #1, but wanted a more "portable" approach like
#2. Thanks for the pointers, it will give me something to work with.
- Jackie
Paul Spencer-2 wrote:
> Jackie,
> you have two choices
> 1) in your template (which you don't want but which I am including for
> completeness and also because widgets will work with selections in
> much the same way)
> Fusion.registerForEvent(Fusion.Event.FUSION_INITIALIZED, function() {
> var map = Fusion.getMapByIndice(0); // or getMapById()
> map.registerForEvent(Fusion.Event.MAP_SELECTION_ON, handleSelection);
> map.registerForEvent(Fusion.Event.MAP_SELECTION_OFF, clearSelection);
> function handleSelection() {
> map.getSelection(selectionCallback);
> function selectionCallback(sel) {
> // sel is a selection object with a collection of
> SelectionObject.Layer objects
> for (var i=0; i<sel.getNumLayers(); i++) {
> var selLayer = sel.getLayer(i);
> // selLayer has:
> // getName, getNumElements, getNumProperties, getPropertyNames,
> getPropertyTypes, getElementValue
> function clearSelection() {
> // the user cleared the selection
> 2) in a widget
> /* a widget that loads a url in the task pane when a selection is made
> * <Widget>
> * <Name>SomeId</Name>
> * <Type>MySelectionHandler</Type>
> * <Extension>
> * <Target>TaskPane</Target>
> * <Url>path/to/my/code</Url>
> * </Extension>
> * </Widget>
> Fusion.Widget.MySelectionHandler = OpenLayers.Class(Fusion.Widget, {
> target: null,
> url: null,
> initializeWidget: function(widgetTag) {
> var json = widgetTag.extension;
> this.target = json.Target ? json.Target[0] : "TaskPane";
> this.url = json.Url ? json.Url[0] : null;
> this.getMap().registerForEvent(Fusion.Event.MAP_SELECTION_ON,
> OpenLayers.Function.bind(this.selectionOn, this));
> this.getMap().registerForEvent(Fusion.Event.MAP_SELECTION_OFF,
> OpenLayers.Function.bind(this.selectionOFf, this));
> selectionOn: function() {
> if (this.url) {
> var taskPaneTarget = Fusion.getWidgetById(this.target);
> if (taskPaneTarget) {
> var map = this.getMap();
> var mapLayers = map.getAllMaps();
> var params = [];
> params.push('LOCALE='+Fusion.locale);
> params.push('SESSION='+mapLayers[0].getSessionID());
> params.push('MAPNAME='+mapLayers[0].getMapName());
> params.push('POPUP=false');
> if (url.indexOf('?') < 0) {
> url += '?';
> } else if (url.slice(-1) != '&') {
> url += '&';
> url += params.join('&');
> taskPaneTarget.setContent(url);
> selectionOff: function() {
> The only problem with this widget is that it is not included in the
> application by default, which is a limitation I hope to fix some time,
> so you need to include <div id="SomeId"></div> in your template. Or,
> actually, you can add it to a toolbar or menu
> <Item>
> <Function>Widget</Function>
> <Widget>SomeId</Widget>
> </Item>
> and it will be created with no UI
> Hope this works (untested though) or at least gets you going in the
> right direction.
> Cheers
> Paul
> On 22-Jul-09, at 9:04 PM, Jackie Ng wrote:
>> Hi All,
>> We have maps where we need to perform an action (load a url in the
>> task
>> pane) in response to a map selection.
>> In the AJAX viewer, it would be a simple case of hooking into the
>> viewer
>> events and overriding the selection handler
>> (http://trac.osgeo.org/mapguide/wiki/CodeSamples/JavaScript/AJAXViewerEventHooking
>> But in Fusion, with its template and widget driven approach, this
>> seems to
>> be a bad idea. So, short of hacking each template to support this
>> functionality (worst case), it is possible to make a "startup"
>> widget that
>> listens to the widget events I'm after and bind them to inline code
>> also
>> defined in the widget. Sort of like a automatic InvokeScript?
>> - Jackie
>> View this message in context:
>> http://n2.nabble.com/Startup-widgets-possible--tp3306936p3306936.html
>> Sent from the Fusion Users mailing list archive at Nabble.com.
>> fusion-users mailing list
>> fusion-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
> Paul Spencer
> Chief Technology Officer
> DM Solutions Group Inc
> http://research.dmsolutions.ca/
View this message in context: http://n2.nabble.com/Startup-widgets-possible--tp3306936p3313889.html
More information about the fusion-users
