[fusion-users] Fusion Conversion: 1.x -> 2.x
Paul Deschamps
pdeschamps at dmsolutions.ca
Mon Jun 8 09:38:59 EDT 2009
Hi Tim,
I have been unable to reproduce this issue with the current rev# 1863 of
fusion. It looks to me that something in your loadmap.php script is not
passing the image type to openlayers so the default action is set.
Have you modified anything in loadmap.php? perhaps you can send an
attachment of the response from loadmap.php? or even better provide a link
to the offending application.
See: trunk/lib/OpenLayers/OpenLayers.js around line 29288
DEFAULT_PARAMS: {
mode: "map",
map_imagetype: "png"
by default the map_imagetype is png. see what happens if you change it to
this.
DEFAULT_PARAMS: {
mode: "map",
map_imagetype: "aggapng24"
Cheers
Paul D.
On Thu, Jun 4, 2009 at 4:19 PM, Nolte, Tim <Tim.Nolte at ipcswirelessinc.com>wrote:
> I can assure you that there is something wrong with how Fusion is
> handling my mapfile. I changed my IMAGETYPE to what you had and still
> found that it was generating a GD image. So I did some digging. Here is
> the url that was being passed to the mapserv cgi:
> http://mapserver.ilpcs.com/cgi-bin/mapserv?layers=world_countries_large_
> scale%20world_countries_mid_scale%20world_countries_small_scale1%20world<http://mapserver.ilpcs.com/cgi-bin/mapserv?layers=world_countries_large_%0Ascale%20world_countries_mid_scale%20world_countries_small_scale1%20world>
> _countries_small_scale2%20built_up_areas%20voice_only_roaming%20voice_da
> ta_roaming%20ipcs_voice_data%20ipcs_evdo%20inland_water_small_scale%20in
> land_water%20inland_water_no_us%20rivers_and_streams_with_US%20rivers_an
> d_streams_no_US%20canals_no_US%20regional_borders%20international_border
> s%20roads%20roads_median%20railroads%20sea_labels%20ocean_labels%20built
> _up_area_labels%20state_province_labels%20world_major_cities%20world_cap
> itals%20island_labels%20inland_water_small_scale%20inland_water%20us_wat
> er%20us_rivers_streams%20us_small_scale_state_borders%20us_large_scale_s
> tate_borders%20us_international_borders%20us_ramps%20us_trails%20us_ferr
> ies%20us_streets_for_raster%20us_railways%20us_small_scale_secondary_roa
> ds%20us_secondary_roads%20us_small_scale_primary_roads%20us_primary_road
> s%20us_primary_road_shields_small_scale%20us_primary_road_shields%20us_s
> econdary_road_shields_small_scale%20us_secondary_road_shields%20small_to
> wns%20towns%20small_cities%20medium_cities%20major_cities_100000%20major
> _cities_1000000%20capital_cities%20state_labels%20national_capitals%20on
> _air%20copyright&session=4a2828d05bdbc&map=%2Ftmp%2Fsess_4a2828d05bdbc%2
> FiPCS.map&map_imagetype=png&mode=map&ts=1244145893344&mapext=-86.5204549
> 4505495+42.08666860282567+-84.71641412872842+43.798194505494436&imgext=-
> 86.52045494505495+42.08666860282567+-84.71641412872842+43.79819450549443
> 6&map_size=780+740&imgx=390&imgy=370&imgxy=780+740
> If you look for the map_imagetype you'll see that it is being set to
> "png". This is not a valid type in my file. I changed this to my valid
> AGG imagetype:
> FiPCS.map&map_imagetype=aggapng24&mode=map&ts=1244145893344&mapext=-86.5
> 2045494505495+42.08666860282567+-84.71641412872842+43.798194505494436&im
> gext=-86.52045494505495+42.08666860282567+-84.71641412872842+43.79819450
> 5494436&map_size=780+740&imgx=390&imgy=370&imgxy=780+740
> And wouldn't you know I got the expected results. So it would seem that
> Fusion is looking at the MIMETYPE or DRIVER and using the generic image
> type rather than using the IMAGETYPE setting that I specified in my
> mapfile. I'm going to look into the Fusion code to find out how it is
> reading the mapfile and getting that imagetype setting. For now I can
> make sure that I only have the AGG output method specified with the
> generic JPEG or PNG naming.
> ** Also, please reply-to-all when responding to these posts. If you
> respond only to the poster then the community doesn't not get the whole
> conversation and misses out on the benefits.
> Timothy J Nolte - tnolte at ilpcs.com
> Network Planning Engineer
> iPCS Wireless, Inc.
> 4717 Broadmoor Ave, Suite G
> Kentwood, MI 49512
> Office: 616-656-5163
> PCS: 616-706-2438
> Fax: 616-554-6484
> Web: www.ipcswirelessinc.com
> -----Original Message-----
> From: pdescham49 at gmail.com [mailto:pdescham49 at gmail.com] On Behalf Of
> Paul Deschamps
> Sent: Thursday, June 04, 2009 2:50 PM
> To: Nolte, Tim
> Subject: Re: [fusion-users] Fusion Conversion: 1.x -> 2.x
> I can definitively say that fusion is not changing the outputformat.
> Fusion calls the mapserver CGI which in tern opens up the mapfile
> specified in the url.
> If the mapfile located in your session folder has aggjpeg then the
> mapserver cgi is using aggjpeg.
> here's an example call to the mapserv cgi:
> http://127.0.0.1:8082/cgi-bin/mapserv?layers=bathymetry%20land_fn%20park
> %20drain_fn%20drainage%20prov_bound%20fedlimit%20popplace&session=4a2812
> d39555f&map=%2Fhome%2Fpdeschamps%2Ffgs%2Ftmp%2F%2Fsess_4a2812d39555f%2FD
> EMO.map&map_imagetype=png&mode=map&ts=1244140254648&mapext=-2925864.1788<http://127.0.0.1:8082/cgi-bin/mapserv?layers=bathymetry%20land_fn%20park%0A%20drain_fn%20drainage%20prov_bound%20fedlimit%20popplace&session=4a2812%0Ad39555f&map=%2Fhome%2Fpdeschamps%2Ffgs%2Ftmp%2F%2Fsess_4a2812d39555f%2FD%0AEMO.map&map_imagetype=png&mode=map&ts=1244140254648&mapext=-2925864.1788>
> 99084+699102.2825688068+3798664.178899084+2428266.717431193&imgext=-2925
> 864.178899084+699102.2825688068+3798664.178899084+2428266.717431193&map_
> size=805+207&imgx=402.5&imgy=103.5&imgxy=805+207
> You can even change the mapfile in a text editor and refresh that url
> and the map will change.
> Perhaps what you are seeing is compression artifacts.I would suggest
> changing from aggjpeg to aggpng24 transparent(alpha)
> Hope this helps
> Paul D.
> OUTPUTFORMAT
> NAME 'AGGA'
> DRIVER AGG/PNG
> IMAGEMODE RGBA
> END
> On Thu, Jun 4, 2009 at 12:51 PM, Nolte, Tim
> <Tim.Nolte at ipcswirelessinc.com> wrote:
> Q1: Yes mapfile that is generated also has aggjpeg set the for
> image
> type.
> Q2: I can tell that it is not using AGG because the symbols and
> layers
> are not anti-aliased. I have a Chameleon app that uses the same
> exact
> output format and I get nice anti-aliased maps.
> - Tim
> iPCS Wireless, Inc.
> Kentwood, MI 49512
> PCS: 616-706-2438
> Fax: 616-554-6484
> Behalf Of
> Paul Deschamps
> Sent: Thursday, June 04, 2009 12:02 PM
> To: Nolte, Tim
> Here's a q. If you navigate into your php session directory and
> then
> into the active session and open up the mapfile that is inside
> there is
> it the image type aggjpeg? as it is below? that you are seeing
> below?
> Another Q: How are you making this determination that mapserver
> is using
> GD?
> Cheers
> Paul.
> Paul Deschamps
> Applications Specialist
> DM Solutions Group Inc.
> Office: (613) 565-5056 x28
> http://www.dmsolutions.ca
> http://research.dmsolutions.ca
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
Paul Deschamps
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20090608/22242938/attachment-0001.html
More information about the fusion-users
