[fusion-users] Custom Widgets Placement
Chris Claydon chris.claydon at autodesk.com
Mon Jun 22 14:18:12 EDT 2009
You can specify a <Location> parameter in your widget info file, and
in the actual widget reference. I believe the path you specify is a
folder relative to the main fusion folder. The ext folder is a good
place for custom widget implementations. The widget info file still
needs to go into widgets/widgetinfo however.
Chris.
Sent from my iPhone
On 2009-06-22, at 12:07 PM, "Nolte, Tim"
<Tim.Nolte at ipcswirelessinc.com> wrote:
> Can I put custom widgets in any other place other than within the
> Fusion->Widgets folder? I'm just concerned about updating Fusion
> versions an not blowing away my custom widgets.
> - Tim
> Timothy J Nolte - tnolte at ilpcs.com
> Network Planning Engineer
> iPCS Wireless, Inc.
> 4717 Broadmoor Ave, Suite G
> Kentwood, MI 49512
> Office: 616-656-5163
> PCS:    616-706-2438
> Fax:    616-554-6484
> Web: www.ipcswirelessinc.com
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users mailing list
