[fusion-users] MapServer/Fusion 2.0/SelectionPanel
Paul Spencer
pspencer at dmsolutions.ca
Wed Jun 24 09:29:14 EDT 2009
Excellent! Glad to help out.
Paul
On 24-Jun-09, at 9:02 AM, Nolte, Tim wrote:
> Perfect. I was on the right track with trying to register and event
> handler. Just had to get it in the right place and call the right
> action
> when the event triggered. This is working exactly the way I wanted.
> Also, I wasn't so much looking for any animation effects. I'm not sure
> if that is really necessary for Fusion, might be more or less just
> added
> bloat.
> - Tim
> Timothy J Nolte - tnolte at ilpcs.com
> Network Planning Engineer
> iPCS Wireless, Inc.
> 4717 Broadmoor Ave, Suite G
> Kentwood, MI 49512
> Office: 616-656-5163
> PCS: 616-706-2438
> Fax: 616-554-6484
> Web: www.ipcswirelessinc.com
> -----Original Message-----
> From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
> Sent: Wednesday, June 24, 2009 7:16 AM
> To: Nolte, Tim
> Cc: fusion-users at lists.osgeo.org
> Subject: Re: [fusion-users] MapServer/Fusion 2.0/SelectionPanel
> One of the things that is not in jxlib is animation effects for things
> like opening dialogs, panels, menus, flyouts etc - there really should
> be a way of doing that! In any case, you can open the panel by
> calling panelSelection.toggleCollapse(false) if the panel is used by
> itself or by calling panelSelection.maximize() if it is part of a
> Jx.PanelSet.
> You can use events to determine when to do this,
> //assuming your map is in a div with an id of 'Map' ...
> //open the panel when a selection has been made
> Fusion
> .getMapById('Map').registerForEvent(Fusion.Event.MAP_SELECTION_ON,
> function() {
> panelSelection.toggleCollapse(false);
> //close the panel when the selection has been cleared?
> Fusion
> .getMapById('Map').registerForEvent(Fusion.Event.MAP_SELECTION_OFF,
> function() {
> panelSelection.toggleCollapse(true);
> Cheers
> Paul
> On 23-Jun-09, at 4:54 PM, Nolte, Tim wrote:
>> So does anyone know how I would go about triggering the
>> SelectionPanel
>> top open when I use the Select tool? Currently in my JavaScript I
>> have
>> defined:
>> var panelSelection = new Jx.Panel({
>> label: 'Selection',
>> content: 'SelectionPanel',
>> collapse: false,
>> maximize: true,
>> closed: true
>> This is so that the Legend is maximized and the SelectionPanel is
>> closed. I'd like for the SelectionPanel to fly open to show the query
>> results after I use the Select tool. Anyone tried this?
>> iPCS Wireless, Inc.
>> Kentwood, MI 49512
>> PCS: 616-706-2438
>> Fax: 616-554-6484
>> From: Nolte, Tim
>> Sent: Tuesday, June 23, 2009 3:49 PM
>> To: fusion-users at lists.osgeo.org
>> Subject: RE: [fusion-users] MapServer/Fusion 2.0/SelectionPanel
>> OK, so stupid me I didn't have the TEMPLATE line for the layers I
>> wanted
>> selectable. This took care of it for me. Now if I could only figure
>> out
>> a way to make a pretty transparent highlight instead of the mapfile
>> HIGHLIGHT that changes the color completely of the object(s)
>> selected.
>> - Tim
>> iPCS Wireless, Inc.
>> Kentwood, MI 49512
>> PCS: 616-706-2438
>> Fax: 616-554-6484
>> Sent: Tuesday, June 23, 2009 2:08 PM
>> To: Nolte, Tim
>> Fusion only seems to need the metadata "selectable" on mapserver
>> layers to determine if features can be selected from any given layer.
>> You may need to also include a template in your layer so that
>> mapserver itself thinks the layer can be queried.
>> TEMPLATE "ttt.html"
>> Can you test with a shape file to see if perhaps selection works with
>> them?
>> Paul
>> On 23-Jun-09, at 12:15 PM, Nolte, Tim wrote:
>>> I'm trying to figure out how to get selections working in Fusion
>>> 2.0. I
>>> have:
>>> METADATA
>>> "groupLegendLabel" "Cell Sites"
>>> "groupExpandInLegend" "false"
>>> "legendLabel" "On-Air"
>>> "selectable" "true"
>>> "query_include_items" "all"
>>> END
>>> For my METADATA on my individual layer. But when I try to use the
>>> selection tool and select one of these objects I get nothing. I'm
>>> running MapServer 5.4 & Fusion 2.0. This layer is an Oracle spatial
>>> query resulting in points.
>>> - Tim
>>> iPCS Wireless, Inc.
>>> Kentwood, MI 49512
>>> PCS: 616-706-2438
>>> Fax: 616-554-6484
>>> fusion-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>> Paul Spencer
>> Chief Technology Officer
>> DM Solutions Group Inc
>> http://research.dmsolutions.ca/
> Paul Spencer
Paul Spencer
More information about the fusion-users
