[fusion-users] Problems using map.query() method
Tom Lazo
tom.lazo at hotmail.com
Tue May 12 17:51:01 EDT 2009
I got it! xD
options.selectionType = 'INTERSECTS';
options.maxFeatures = 0;
//options.computed = this.bComputeMetadata;
options.layers = 'LOTES';
options.extendSelection = true;
//options.computed = false;
options.filter = '([ID_FICHA] = '+ idFicha + ' )';
this' the right way :D. I'd missed the '('
Thanks
Tom Lazo wrote:
> Hi Vitor,
> I have a problem here. I use Fusion with MapServer and i'm trying to
> filter some features from a layer with this code:
> options.filter = 'ID_FICHA = 193';
> this.getMap().query(options);
> But it paints me the entire map when it's suppose just to paint the
> feature with the id = 193.
> I've changed the Query.php just like you did, but noth.
> Please tell me where is my mistake.
> Thanks
> Tom
> Vitor Fortunato wrote:
>> I made it!
>> I've just change the line
>> if (@$oLayer->queryByShape($oSpatialFilter) == MS_SUCCESS) {
>> for
>> if (@$oLayer->queryByAttributes($field, $filter, MS_MULTIPLE) ==
>> MS_SUCCESS)
>> where:
>> - $field is the item (attribute) on wich the query is performed;
>> - $filter is the expression
>> - MS_MULTIPLE allow to selection of all records returned (use MS_SINGLE
>> to
>> select only the first record)
>> Ex.: queryByAttributes('gid', 'gid in (1, 2, 3)', MS_MULTIPLE)
>> I am a little bit confused about the $field parameter, because I can set
>> it
>> to be any field of the layer, it don't affects the query. But I have to
>> set
>> a valid field of the layer...
>> in the $filter parameter I can use any "where" expression supported by
>> PostGIS (st_intersects, st_area, in, and, like ...)
>> I am using a mapfile pointing to tables in PostGIS..
>> PS.: I don't known how to call queryByShape and queryByAttributes at the
>> same time and combine the results!
>> Reference of the queryByAttributes method:
>> http://mapserver.gis.umn.edu/docs/reference/phpmapscript-class/classes/layerobj
>> Best Regards
>> Vitor Fortunato
>> On Sat, May 31, 2008 at 9:30 PM, Paul Spencer <pspencer at dmsolutions.ca>
>> wrote:
>>> Vitor,
>>> you are not doing anything wrong, the mapserver code for the query()
>>> function just hasn't been updated to use the filter value in Query.php
>>> (although it does parse it from the request parameters).
>>> Patches welcome :)
>>> Cheers
>>> Paul
>>> On 29-May-08, at 6:03 AM, Vitor Fortunato wrote:
>>> I am having problems to use the map.query() method to filter
>>> attributes.
>>>> In this method you can send a SQL filter inside the options parameter.
>>>> But it didn't works for me...
>>>> I think the query method is ignoring this parameter.
>>>> I've found the code bellow in the query.php file, and it seems that
>>>> this
>>>> file is not using the filter parameter...
>>>> The code bellow, shows only the queryByShape using the $oSpatialFilter
>>>> parameter...
>>>> $result->hasSelection = true;
>>>> $layerName = $oLayer->name;
>>>> array_push($result->layers, $layerName);
>>>> $result->$layerName->featureCount = $oLayer->getNumResults();
>>>> //TODO: dump out the extents of the selection
>>>> I have a simple widget that uses the following code:
>>>> execute : function() {
>>>> var options = {};
>>>> options.geometry = "POLYGON((-75.58840579710144 -10.755072463768112,
>>>> -61.16086956521739 -10.755072463768112, -61.16086956521739
>>>> 0.005797101449276809, -75.58840579710144 0.005797101449276809,
>>>> -75.58840579710144 -10.755072463768112))";
>>>> options.filter = "gid=1"
>>>> options.layers = 'States';
>>>> the polygon intersects with 5 states, but I would like to select just
>>>> the
>>>> state with 'gid = 1', using the filter option.
>>>> My code select the 5 states that intersect with the polygon and don't
>>>> apply the filter.
>>>> What I am doing wrong?
>>>> _______________________________________________
>>>> fusion-users mailing list
>>>> fusion-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>>> Paul Spencer
>>> Chief Technology Officer
>>> DM Solutions Group Inc
>>> http://www.dmsolutions.ca/
View this message in context: http://n2.nabble.com/Problems-using-map.query%28%29-method-tp2061713p2873461.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users
