[fusion-users] Fusion onInitialize query
Cristi Teodoreanu
tecrif at yahoo.com
Wed Sep 2 06:37:07 EDT 2009
I'm trying to create a custom query for a layer filtering when the map loads.
Basically the code I'm executing in the var fusionInitialized function is:
var map = Fusion.getWidgetById('Map');
var options = {};
options.maxFeatures = 0;
options.layers = '(Points)';
options.filter = '(PointNr LIKE \'%007%\')';
map.query(options);
However, the query execution throws an exception:
Fusion Error:
WARNING: Exception occurred in AJAX callback.
Message: invalid label
Location: http://localhost:8008/mapguide/fusion/MapGuide/MapGuide.js (774)
Response: ERROR: Argument is null.
Argument is null.
Exception occurred in method MgResourceIdentifier.CheckName at line 624 in
file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\platformbase\Services/ResourceIdentifier.cpp
- MgMap.Open line 457 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\mapguidecommon\MapLayer/Map.cpp
- MgResourceIdentifier.CheckName line 624 file
I have debugged the query process from MapGuide.js - query :
function(options) - adding the alert massage as shown below:
var ajaxOptions = {
onSuccess: OpenLayers.Function.bind(this.processQueryResults,
this, zoomTo),
parameters: params};
/* >>>>>> */ alert('mapname:
'+params.mapname+'\nsessionid:'+params.sessionid+'\nlayers:
'+params.layers+'\nfilter: '+params.filter);
Fusion.ajaxRequest(loadmapScript, ajaxOptions);
The message shows that at the execution of the query both the mapname and
sessionid are not defined for the map
mapname: undefined
sessionid:undefined
layers: (Waterpoints)
filter: (WaterPointNr LIKE '%007%')
Q: Since the fusionInitialized is registered to be executed on
Fusion.Event.FUSION_INITIALIZED, what is the problem with the above test ?
My idea was that the map should have been fully loaded by then and the
filter queried ok.
Thank you,
Cristi Teodoreanu
View this message in context: http://n2.nabble.com/Fusion-onInitialize-query-tp3565949p3565949.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users
