[fusion-users] Proper Class Names in MapServer Mapfile
Nolte, Tim Tim.Nolte at ipcswirelessinc.com
Wed Sep 9 10:42:18 EDT 2009
Does anyone object if I just build a ticket in Trac for this? I'm
proposing this as a change to the 2.0 branch.
- Tim
Timothy J Nolte - tnolte at ilpcs.com
Network Planning Engineer
iPCS Wireless, Inc.
4717 Broadmoor Ave, Suite G
Kentwood, MI 49512
Office: 616-656-5163
PCS:    616-706-2438
Fax:    616-554-6484
Web: www.ipcswirelessinc.com
-----Original Message-----
[mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Nolte, Tim
Sent: Wednesday, September 09, 2009 9:40 AM
To: Julien-Samuel Lacroix
Cc: dmorissette at mapgears.com; fusion-users at lists.osgeo.org
Subject: RE: [fusion-users] Proper Class Names in MapServer Mapfile
It would seem to me that if $class->title was add that long ago there
should be no question of whether this can be incorporated into Fusion. I
wouldn't think people would be using Fusion with anything older then 4.x
MapServer/MapScript.
- Tim
iPCS Wireless, Inc.
Kentwood, MI 49512
PCS:    616-706-2438
Fax:    616-554-6484
From: Julien-Samuel Lacroix [mailto:jlacroix at mapgears.com]
Sent: Wednesday, September 09, 2009 9:31 AM
To: Nolte, Tim
Subject: Re: [fusion-users] Proper Class Names in MapServer Mapfile
It seems to have been added in MapServer 3.6. I'm not sure if Fusion
with a version that old.
http://trac.osgeo.org/mapserver/changeset/1389
Julien
Nolte, Tim wrote:
> Daniel,
> Do you have further insight into Paul's question?
> - Tim
> iPCS Wireless, Inc.
> Kentwood, MI 49512
> PCS:    616-706-2438
> Fax:    616-554-6484
> From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
> Sent: Tuesday, September 08, 2009 4:48 PM
> To: Nolte, Tim
> Cc: fusion-users at lists.osgeo.org
> Tim, do you know in which mapserver version $class->title got added to
> mapscript?  What will happen in older mapserver installs, will it
> return an empty string?
> Paul
> On 2009-09-08, at 4:45 PM, Nolte, Tim wrote:
>> OK, so I decided to do a little digging in the MapServer code. I'd
>> like
>> to propose the following code change in the LoadMap.php:
>>         //create classes and slot them into the scale breaks
>>         for ($j=0; $j<$layer->numclasses; $j++) {
>>             $oClass = $layer->getClass($j);
>>             $classObj = NULL;
>>             // Use formatted legend label as defined by CLASS->TITLE
>>             $classObj->legendLabel = $oClass->title != '' ?
>> $oClass->title : $oClass->name;
>>             //$classObj->legendLabel = $oClass->name;
>>             $classObj->filter = $oClass->getExpression();
>>             $classMin = $oClass->minscale == -1 ? $layerMin :
>> max($oClass->minscale, $layerMin);
>>             $classMax = $oClass->maxscale == -1 ? $layerMax :
>> min($oClass->maxscale, $layerMax);
>>             $classObj->minScale = $classMin;
>>             $classObj->maxScale = $classMax;
>>             $classObj->index = $j;
>>             for ($k=0; $k<count($aScaleRanges); $k++) {
>>                 if ($classMin < $aScaleRanges[$k]->maxScale &&
>>                     $classMax > $aScaleRanges[$k]->minScale) {
>>                     array_push($aScaleRanges[$k]->styles, $classObj);
>> This block starts around line 306. My code change looks for a
>> CLASS->TITLE and uses that and if not found falls back on the
>> CLASS->NAME. I've tested and it works perfectly! I would really like
>> to
>> not have to manually maintain my custom code here. Thanks!
>> - Tim
>> iPCS Wireless, Inc.
>> Kentwood, MI 49512
>> PCS:    616-706-2438
>> Fax:    616-554-6484
>> From: fusion-users-bounces at lists.osgeo.org
>> Sent: Tuesday, September 08, 2009 4:14 PM
>> To: fusion-users at lists.osgeo.org
>> Subject: [fusion-users] Proper Class Names in MapServer Mapfile
>> I have figured out how to give properly formatted names to groups and
>> layers. The problem I run into now is I have a few layers that I am
>> classifying. These classified layers are showing the crude CLASS ->
>> NAME
>> (e.g. 'on_air_evdo') but I want to have Fusion show a properly
>> formatted
>> name (e.g. 'EVDO On-Air'). Thanks.
>> - Tim
>> iPCS Wireless, Inc.
>> Kentwood, MI 49512
>> PCS:    616-706-2438
>> Fax:    616-554-6484
>> fusion-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>     Paul Spencer
>     Chief Technology Officer
>     DM Solutions Group Inc
>     http://research.dmsolutions.ca/
Mapgears
http://www.mapgears.com/
More information about the fusion-users mailing list
