[fusion-users] Re: Map Name as a parameter for FUSION
Mike Adair
madair at dmsolutions.ca
Wed Feb 3 16:18:04 EST 2010
You would have to modify layers/mapguide/MapGuide.js. That is where the
LoadMap call originates for MapGuide layers and you should be able to
see where the 'theme' is parsed out and do something similar.
Mike
Rodolfo Moreno wrote:
> Hi Mike, could you give me some clue about where I can modify?
> It is what I was thinking about your idea:
> - Add mapname parameter at the begining (e.g.
> index.html?session=mySessionId&mapname=myMapname)
> - Inside of fusion.js capture the mapname parameter and send it to
> loadMap.php script
> I have been reviewing the fusion.js but I haven't found the right place
> where it call to the loadmap.php. Also I reviewed the map.js with the same
> aim but with no success.
> thanks in advance,
> Rodolfo Moreno
> CivilEng
Michael Adair
Senior Software Architect
DM Solutions Group Inc.
Office: (613) 565-5056 x26
http://www.dmsolutions.ca
http://research.dmsolutions.ca
More information about the fusion-users
