[fusion-users] RedLine
Josvil
josue.villarreal at gmail.com
Tue Feb 23 12:33:01 EST 2010
Using the widget Redline, add two icons, one to create points and the other
to create lines, the problem is as follows:
When I click on the icon of the point and then click on the icon of the
line, gives the following javascript error:
"this.activeControl is null" Redline.js line 216
What causes the need to hit back on the line icon to activate the
functionality.
Then place the code used:
" <Widget xsi:type="UiWidgetType">
<Name>dibujarPunto</Name>
<Type>Redline</Type>
<Extension>
<FeatureStyle>
<fillColor>#0f0Ff0</fillColor>
<strokeColor>#0133F1</strokeColor>
<strokeWidth>2</strokeWidth>
</FeatureStyle>
<DefaultControl>Point</DefaultControl>
<activeControl>Control</activeControl>
</Extension>
<ImageUrl>images/icons/point.gif</ImageUrl>
<Tooltip>Crear un punto</Tooltip>
<StatusText/>
<Disabled>false</Disabled>
</Widget>
<Name>dibujarLinea</Name>
<StatusItem>Digitizing tool</StatusItem>
<Extension xsi:type="CustomContentType">
<FeatureStyle>
<fillColor>#FFFFFF</fillColor>
<strokeColor>#FFFFFF</strokeColor>
</FeatureStyle>
<DefaultControl>Line</DefaultControl>
</Extension>
<ImageUrl>images/icons/linea.gif</ImageUrl>
<Tooltip>Dibujar línea</Tooltip>
<Disabled/>
</Widget> "
Any information about it please warn me
Greetings
View this message in context: http://n2.nabble.com/RedLine-tp4620450p4620450.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users
