[fusion-users] selection problems
jbogdani
jbogdani at gmail.com
Wed Jun 16 10:46:51 EDT 2010
Hello all,
I have the following problem: I can select fetures on a layer only when all
the other layers are off.
For an example please visit: http://webgis.dyndns.info/webgis/suasa2/
when "Roads" is off I can select on Sites, but if I turn "Roads" on when I
select I can see the resulte of the query on the left, but the map
disappears.
To better understand:
1- go to: http://webgis.dyndns.info/webgis/suasa2/
2- select something
everything works fine
3- turn roads lauer on
4- select something
map disappears, selection result regularly on left panel.
Here is my very simple map file:
MAP
IMAGETYPE PNG24
EXTENT 324926 4823738 345480 4840561
SIZE 400 300
SHAPEPATH "SHP/"
SYMBOLSET "../fusion-utilities/symbols.sym"
IMAGECOLOR 255 255 255
QUERYMAP
STYLE HILITE
COLOR 255 0 0
END
LAYER
NAME Roads
DATA "roads"
STATUS OFF
TYPE LINE
CLASS
NAME 'roads'
STYLE
COLOR 213 0 213
END
END
END
LAYER
NAME Sites
DATA "Sites"
STATUS ON
TYPE POINT
CLASS
TEMPLATE "aStringHere"
NAME 'sites'
SYMBOL 'square'
SIZE 4
COLOR 0 0 0
END
END
END
END
View this message in context: http://osgeo-org.1803224.n2.nabble.com/selection-problems-tp5186819p5186819.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users
