[fusion-users] Can't create a session
Mike Adair madair at dmsolutions.ca
Wed Jun 16 15:36:15 EDT 2010
Pedro,
I don't know IIS very well at all, but that definitely sounds like a
path issue.  It would be best if you can put the Fusion directory so
that you can reference one of the default templates as
myserver.com/fusion/templates/mapserver/standard.  Your own application
template can then be at myserver.com/myTemplate and reference Fusion in
the script tag either absolutely as /fusion/lib/fusion.js or set up a
relative path.
Not sure if that helps or not...
Mike
Pedro Montezinho wrote:
> Hello,
> In the IIS, i've a virtual directory to mapguide. In this directory i
> can test the templates in the Fusion folder, and i can create my own
> project in this folder.
> But if i create another virtual directory and put all the same files
> that are in the mapguide virtual directory, i can't test or view any
> of the templates in the Fusion folder.
> I've used the Fiddler application to watch witch file is not working.
> I've discovered that the CreateSession.php is not working, but i don't
> know how...
> Can you guys give me some help.
> Thanks
> Cheers.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users mailing list
