[fusion-users] Fusion Layout Remove Login
Alan Boudreault aboudreault at mapgears.com
Fri Jun 25 12:48:42 EDT 2010
I don't know much about MapGuide..... but the only way I found to do that was
to create an Anonymous user in the web interface (with the proper rights) and
to add "&USERNAME=Anonymous" in the URL.
Alan
On June 18, 2010 12:04:19 pm Erik Heinze-Milne wrote:
> What I am trying to do is create a fusion layout that doesn't require the
> user to login in through mapguide in order to use the viewer. Whether I can
> somehow pass in log in credentials to the viewer automatically or bypass
>  the login entirely doesn't matter as long as the process is invisible to
>  the user.
> I have tried copying the layout to another location, but then that causes
> problems with being able to edit it in MapGuide Studio 2009, which I still
> need to be able to do as well.
Alan Boudreault
Mapgears
http://www.mapgears.com
More information about the fusion-users mailing list
