[fusion-users] Re: Overview Map
    Kori Maleski
    kori.maleski at gmail.com
    Thu Mar 18 13:33:12 EDT 2010
I am using trunk as well.
What I have found is that the OpenLayers.Layer.MapGuide Layer does not hold
the proper projection after a map definition has been loaded.   It retains
the default 4326  LL84 projection.  The map object itself holds the correct
projection - whatever has been set in the MapDefinition in Studio.  This
causes no issue until a widget tries to grab the maps projection - such as
the overview.
So it is an issue with the OpenLayers.Layer.MapGuide class perhaps?
Cheers,
Kori Maleski
On Thu, Mar 18, 2010 at 9:37 AM, Mark Pendergraft <markp at meadgilman.com>wrote:
> I'm using trunk.  There is only 1 map in my AppDef and both the Map and
> Overview Map reference it.  The map is in EPSG:2926, and has that same
> projection defined in the AppDef, but the Overview Map doesn't pick up the
> projection and tries to display itself in LL84 (which is the default
> OpenLayers projection).  I opened a ticket here:
> http://trac.osgeo.org/fusion/ticket/373
> Thanks,
> -Mark
> http://n2.nabble.com/Overview-Map-tp4752630p4757603.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20100318/7bbd78c3/attachment.html
More information about the fusion-users
