[fusion-users] Re: Show Layer added in MapScript
millsde millsde at dfo-mpo.gc.ca
Wed Mar 24 13:27:02 EDT 2010
I'm adding a point to the map instead of a layer.  I tried doing what you
suggested(or at least I think I am)  for the past week now, but cannot get
the updated map to show up in the fusion window.  Although if I save the
image( using $image->saveWebImage() ) the point displays correctly.  Can you
see what I'm doing wrong in my code snip-it?
javascript code ---------------------------------------------------
    handler: function(button) {
		if (button == 'Add') {
			var lat = this.dialog.getValue('Latitude');
			var longit = this.dialog.getValue('Longitude');
			var map = Fusion.getMapByIndice(0);
            var session = 'session='+map.getSessionID();
            var mapName = '&mapname='+ map.getMapName();
            var latparam = '&latitude='+lat;
            var longparam = '&longitude='+longit;
            var params = session+mapName+latparam+longparam;
            var options = {parameters:params, onSuccess:
this.APResults.bind(this)};
            new Ajax.Request(this.queryURL, options);
		this.dialog.close();
	APResults: function(r) {
		var mainMap = this.getMap();
		var aMaps = mainMap.getAllMaps();
		parent.document.getElementById('Map').widget.aMaps[0].reloadMap();
php code -----------------------------------------------------
if ( ($_REQUEST["latitude"] != "") && ($_REQUEST["longitude"] != ""))  {
     $lat = $_REQUEST["latitude"];
     $longit = $_REQUEST["longitude"];
else {
    die('Error: Lat/Long not set');
if (isset($_SESSION['maps']) && isset($_SESSION['maps'][$mapName])) {
    $map = ms_newMapObj($_SESSION['maps'][$mapName]);
else {
    die('Error: Map not set');
$pLayer = ms_newLayerObj($map);
$pLayer->set("name", "New Point");
$pLayer->set("type", MS_LAYER_POINT);
$pLayer->set("status", MS_ON);
$class = ms_newClassObj($pLayer);
$style = ms_newStyleObj($class);
$style->color->setRGB(255,0,0);
$style->set("symbolname", "circle");
$style->set("size", 10);
$my_point = ms_newpointObj();
$my_point->setXY($lat, $longit);
$image=$map->draw();
$my_point->draw( $map, $pLayer, $image, 0, "New Point" );
/*$image_url=$image->saveWebImage();
echo " $image_url "; */
$map->save($_SESSION['maps'][$mapName]);
View this message in context: http://n2.nabble.com/Show-Layer-added-in-MapScript-tp4716387p4792497.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
