[fusion-dev] RE: [fusion-users] v2.0.0 release candidate
available
Zac Spitzer
zac.spitzer at gmail.com
Thu Mar 25 22:11:50 EDT 2010
Is the Sheboygan sample still missing a tiled fusion example?
On 26 March 2010 13:09, Jason Birch <jason at jasonbirch.com> wrote:
> On 1.1, I recently saw a similar (but probably not same) problem when I had
> a map with an invisible layer at the root of the legend tree. Also had
> problems when the legend label _was_ blank in the MapDefinition, and when I
> had layers with undefined min or max scales. I think. Didn't spend the
> time putting together a reproducible test case because 1.1 is so old and I
> had workarounds.
> I wouldn't be surprised if this was hard to troubleshoot without a package
> (data/layers/map/appdef) that demonstrates the problem.
> On 25 March 2010 12:57, Berdel, Brian wrote:
>> No problem
> fusion-dev mailing list
> fusion-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the fusion-users
