[fusion-users] Re: Proposed changes to MapGuideViewerApi.js
(fusion\layers\MapGuide)
Zac Spitzer
zac.spitzer at gmail.com
Thu May 6 22:24:15 EDT 2010
i think using the function is a good idea, your explanation makes
it much clear why this change is required as well
can you file a ticket in trac and attach a patch?
z
On 7 May 2010 12:15, miansi <AndreiSinelnikov at sierrasystems.com> wrote:
> My application layout looks like this:
> <iframe>
> Map
> </iframe>
> <iframe>
> Application
> </iframe>
> So I will hide/unhide iframes emulating switching between map and
> application. In such case if I will try to get the reference to Fusion from
> my application - window.top not working. However, in my case I still have to
> tamper GetFusionWindow function to get the reference to my map inside
> iframe.
> Besides why not to use function which already exists in the javascript file?
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Proposed-changes-to-MapGuideViewerApi-js-fusion-layers-MapGuide-tp5016807p5017540.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the fusion-users
