[fusion-users] Re: I do not recognize "Fusion" in my application:
"Fusion is not defined"
Fixi
apcr at tragsa.es
Tue May 18 02:38:08 EDT 2010
I use MapServer - Pmapper.
I added a layer dynamically Mapscript, the added layer is shown when I do
getAllLayerNames ().
What I want is to update the map to see the added layer.
RefrescaMapa code () I added "pmapper-3.2.0/javascript/src/xmlhttp.js."
Where should I add the reference to Fusion Framework? What map.phtml?.
Was this the way you add it?
<script language="javascript" src../fusion/lib/fusion.js"> </ script>
View this message in context: http://osgeo-org.1803224.n2.nabble.com/I-do-not-recognize-Fusion-in-my-application-Fusion-is-not-defined-tp5050396p5068694.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users
