[fusion-users] ubuntu 10 php 5.3 issues
Paul Spencer
pspencer at dmsolutions.ca
Tue May 18 07:46:28 EDT 2010
We'll need a bit more information. The php version difference is probably causing the problem, did you also upgrade mapserver and recompile it against the new version of PHP? Can you look in the PHP error log (or configure PHP to log errors, then look in it) and see if there are any hints? Note that if you did upgrade mapserver to a newer version at the same time, some things might have changed in mapserver that are preventing the map file from working (such as requiring a starting MAP tag). Also, if you can start fusion in a browser that has console logging (firefox/firebug for instance) then it might be useful to see if there are any errors reported in the console. Sometimes an error in the console is uninformative but the payload of the XHR request indicates the root cause of the problem
Cheers
Paul
On 2010-05-18, at 5:07 AM, jbogdani wrote:
> Hello all,
> I've been using fusion and mapserver for few months.
> I had two identical servers, both are running ubuntu server edition (9.x)
> and fusion worked fine.
> On one of them I upgraded to Ubuntu 10.x and fusion stopped working. The
> fusion / mapserver config files are the same, nothing changed. But fusion
> doesn't load. I can see the general frame, but no data are loading.
> I don't know if it is a php issue (the working server is running 5.2.10 and
> the new one 5.3.2-1).
> This is the reason I stopped upgrading my servers. Can anyone help me
> please?
> I have no problem with other php application on both my servers....
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/ubuntu-10-php-5-3-issues-tp5069084p5069084.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://research.dmsolutions.ca/
More information about the fusion-users
