[fusion-users] No properties shown in selection
gnoviello grazia.noviello at libero.it
Thu Nov 18 03:03:31 EST 2010
I've modified a layer on my map to add a filter at runtime.
To do this, I made the following steps:
1) modifying the session copy of the map file
2) saving the session copy of the map file after modification
3) reloading the map on the client side
Now, I have a problem: on this layer I can't get the properties of selected
objects, so the selection panel is always empty.
I note that the Selection.php request returns this info:
{"layers":[""],"extents":{"minx":1587194.4129254,"miny":4989233.7800054,"maxx":1587194.4129254,"maxy":4989233.7800054},"":{"propertynames":[],"propertyvalues":[],"propertytypes":[],"metadatanames":["dimension","bbox","center","area","length"],"numelements":1,"values":[[]],"metadata":[["","","","",""]]}}
where  is for the name of layer I've modified. I can see the propertynames,
propertytypes,metadatanames arrays are empty.
Has anyone the same problem?
Thanks
Grazia
View this message in context: http://osgeo-org.1803224.n2.nabble.com/No-properties-shown-in-selection-tp5750730p5750730.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
