[fusion-users] MapGroup issue
Zac Spitzer
zac.spitzer at gmail.com
Tue Jan 11 01:20:36 EST 2011
I'm using Mapguide 2.2 RC2 on windows
I am trying to combine a tiled map with a dynamic overlay,
both the map definitions are in the same projection, from the same
mapguide server
The problem I am having is when I zoom or pan, the dynamic layer just isn't
updating, the app layer doesn't come on until i toggle it off and then
on again and
then it is not updated, it gets stuck as per attached screenshots
I'm using the standard mapguide template applicationDefinition with
this as a mapgroup
<MapGroup id="app">
<Map>
<Type>MapGuide</Type>
<SingleTile>false</SingleTile>
<Extension>
<ResourceId>Library://base.MapDefinition</ResourceId>
</Extension>
</Map>
<Map>
<SingleTile>true</SingleTile>
<Extension>
<ResourceId>Library://app.MapDefinition</ResourceId>
</Extension>
<Options>
<isBaseLayer>false</isBaseLayer>
<useOverlay>true</useOverlay>
</Options>
</Map>
</MapGroup>
I tried this with our good old friend the sheboygan sample and had the
same issue.
any ideas?
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/fusion-users/attachments/20110111/b23158d4/overlap_lagging_and_not_updating-0001.jpg
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/fusion-users/attachments/20110111/b23158d4/overlap_lagging_and_not_updating_sheboygan-0001.jpg
More information about the fusion-users
