[fusion-users] Re: Measure Tool for Custom Coords
Michael Adair
madair at dmsolutions.ca
Wed May 4 14:33:06 EDT 2011
I don't see anything wrong in your WKT coordinate string. If I were
debugging this, I would step through the parsing of that WKT string to
make sure it was being parsed correctly (load proj4js-combined.js rather
than proj4js-compressed.js for debug) and then make sure the OpenLayers
map and baseLayer had the correct projection object.
Mike
On 04/05/2011 1:49 PM, GordonL wrote:
> Just a follow up. Any built-in coordinate systems seem to work, but when my
> map is assigned to the coordinate system above, the measure tool is
> 1,000,000-/+ meters too big.
> Any suggestions ?
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Measure-Tool-for-Custom-Coords-tp6158561p6331801.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users
