[fusion-users] Re: selection problems
jbogdani jbogdani at gmail.com
Mon Nov 14 12:34:42 EST 2011
Hello,
I solved the problem, and it is not a Fusion or mapserver problem. It was
(in my case) a mapscript problem. When you install mapscript on a unix
server you should load manually the php_mapscript.so extension in php.ini. I
didn't know this and this was the cause of my problem (mapscript was not
working at all).
I added the extension in php.ini, restarted Apache, and Fusion workes now
like a charm!!
View this message in context: http://osgeo-org.1803224.n2.nabble.com/selection-problems-tp5186819p6993367.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
