[fusion-users] Newbie question: problem parsing Application
Definition
Richard Turner
richardt at mediatel.co.uk
Fri Sep 30 09:34:26 EDT 2011
Hi Paul,
On 30/09/11 12:55, Paul Spencer wrote:
> * what version of fusion are you using? (i.e. did you download a zip or
> are you using svn trunk etc)
I downloaded a zip of 2.2.0.
> * we will need to see your ApplicationDefinition.xml file
Well, I've no idea what I changed, which is pretty irritating, but I'm
getting a map now, albeit without any controls. It seemed to start
working after I moved some lines around in Xml2JSON.php, but having
reverted all my changes (by deleting the whole of Fusion and unzipping a
new copy) and deleting temporary map images it still works. Very weird,
but clearly PEBKAC. Here's the XML though, just for completeness:
<ApplicationDefinition
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="ApplicationDefinition-1.0.0.xsd">
<MapSet xsi:type="MapSetType">x
<MapGroup id="mapserver" xsi:type="MapType">
<Map xsi:type="MapLayerType">
<Type>MapServer</Type>
<SingleTile>true</SingleTile>
<Extension>
<MapFile>/path/to/gmap75.map</MapFile>
</Extension>
</Map>
</MapGroup>
</MapSet>
<WidgetSet xsi:type="WidgetSetType">
<MapWidget xsi:type="WidgetType">
<Name>Map</Name>
<Type>Map</Type>
<StatusItem>The map.</StatusItem>
<MapId>mapserver</MapId>
</MapWidget>
<Widget xsi:type="UiWidgetType">
<Name>Pan</Name>
<Type>Pan</Type>
<Description>Drag the map to view areas out of range.</Description>
<ImageUrl>icons/pan.png</ImageUrl>
<ImageClass/>
<Tooltip>Pan mode</Tooltip>
<Label/>
<Disabled/>
</Widget>
<Name>ZoomIn</Name>
<Type>Zoom</Type>
<Description>Zoom</Description>
<ImageUrl>icons/zoom-in.png</ImageUrl>
<ImageClass/>
<Tooltip>ZoomIn Mode</Tooltip>
<Label/>
<Disabled/>
<Extension xsi:type="CustomContentType">
<Tolerance>5</Tolerance>
<Factor>2</Factor>
</Extension>
</Widget>
<Name>ZoomOut</Name>
<Type>Zoom</Type>
<ImageUrl>icons/zoom-out.png</ImageUrl>
<ImageClass/>
<Tooltip>ZoomOut Mode</Tooltip>
<Label/>
<Disabled/>
<Factor>2</Factor>
<Direction>out</Direction>
</Extension>
</Widget>
<Widget xsi:type="WidgetType">
<Name>Legend</Name>
<Type>Legend</Type>
<StatusItem/>
</Widget>
</WidgetSet>
<Extension/>
</ApplicationDefinition>
> The round trip for ApplicationDefinition.xml is a known problem, it is
> there for historical reasons and there is a mechanism for avoiding it by
> pre-compiling your application, which does a number of things. You seem
> willing to look at the code (which is great!), I suggest that you look
> at the build.xml ANT script to see what happens when you compile an
> application.
OK, that sounds like a good path to start down. Having just started with
the tutorial I haven't read much documentation yet (I'd hoped that the
tutorial would work without needing to), so I didn't know one could
compile an app. Since the other issues I'm seeing, like
fusion/jx/css/jxskin-graphic.css being missing, are probably owing to an
out-of-date tutorial rather than a Fusion problem, I think I'll stop
here and do some reading.
Thanks for your reply, and the hint about compiling an app.
Cheers,
R
More information about the fusion-users
