[fusion-users] Re: Unable to display map using fusion
Badrul
badruls007 at yahoo.com
Wed May 2 06:43:32 EDT 2012
Hi zac
As told by you on twitter to have look at source code, as you can see above
i have included my map file source code and here i am doing it again
MAP
NAME "uktest2"
# Map image size
SIZE 9900 8000
UNITS meters
SHAPEPATH "C:\UKBoundary\UKBoundary.shp"
EXTENT -689447.628994 -22878.477049 1344447.892830 1250227.410037
FONTSET 'C:\fonts.txt'
SYMBOLSET 'C:\symbols.txt'
# Background color for the map canvas -- change as desired
IMAGECOLOR 240 255 240
IMAGEQUALITY 95
IMAGETYPE PNG
OUTPUTFORMAT
NAME agg
DRIVER AGG/PNG
IMAGEMODE RGB
END
LAYER
NAME "UKBoundary"
DATA UKBoundary
STATUS DEFAULT
TYPE LINE
CLASS
NAME 'UKBoundary'
STYLE
WIDTH 4.36
COLOR 0 0 0 #255 140 0
OUTLINECOLOR 94 150 193
END
END
END
LAYER
NAME 'LiveSites'
TYPE POINT
DUMP true
EXTENT 492264.819731 239288.251847 568064.802479 287960.850589
DATA '../../Documents and
Settings/bght1924/Desktop/LiveSites/LiveSites.shp'
#SHAPEPATH "C:\UKBoundary\LiveSites.shp"
METADATA
'ows_title' 'LiveSites'
END
STATUS DEFAULT
TRANSPARENCY 100
CLASS
NAME 'LiveSites'
STYLE
SYMBOL "circle"
SIZE 7.0
OUTLINECOLOR 0 0 0
COLOR 157 88 159
END
END
END
END
Since error is related to imagetype property i am not getting where problem
lies in my map file as i have written following code
IMAGEQUALITY 95
IMAGETYPE PNG
OUTPUTFORMAT
NAME agg
DRIVER AGG/PNG
IMAGEMODE RGB
END
I am not able to understand what is problem with it.
Thanks & Regards
Badrul
View this message in context: http://osgeo-org.1560.n6.nabble.com/Unable-to-display-map-using-fusion-tp4715312p4945860.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users
