[gdal-announce] GDAL 2.4.0 is released
Even Rouault
even.rouault at spatialys.com
Fri Dec 21 05:45:56 PST 2018
On behalf of the GDAL/OGR development team and community, I am pleased to
announce the release of GDAL/OGR 2.4.0. GDAL/OGR is a C++ geospatial
data access library for raster and vector file formats, databases and
web services. It includes bindings for several languages, and a variety
of command line tools.
http://www.gdal.org/
The 2.4.0 release is a new feature release with the following highlights:
* New GDAL drivers:
- BYN: read/write support for Natural Resources Canada's Geoid binary format
- EEDAI: read-only driver for Google Earth Engine Data API
- IGNFHeightASCIIGrid: read-only driver to read IGN-France height correction ASCII grids
- NGW: NextGIS Web read-only driver
- NTv1: read-only driver for NTv1 datum shift grids
* New OGR drivers:
- EEDA: read-only driver for Google Earth Engine Data API
- GeoJSONSeq: read/creation support of new-line or record-separator separated GeoJSON features (#378)
- NGW: NextGIS Web read-write driver
* Improved drivers:
- BAG: add read support for variable-resolution grids, and write support for single-resolution grids
- GTiff driver: add Lerc and WebP codecs
- PostgisRaster: add support for out-db rasters
- RMF
- MSSQLSpatial
* RFC 72: Make GDAL Python autotest suite use pytest framework
* Add /vsihdfs/ virtual file system handler for Hadoop File System (via libhdfs)
* Add /vsiwebhdfs/ read-write virtual file system for Web Hadoop File System REST API
* gdal_contour rewriting: speed optimizations and capability to compute polygon isosurfaces.
* Remove PHP and Ruby bindings.
* Continued code linting in C++, Python scripts, Shell scripts and autotest
More complete information on the new features and fixes in the 2.4.0
release can be found at:
http://trac.osgeo.org/gdal/wiki/Release/2.4.0-News
The release can be downloaded from:
* http://download.osgeo.org/gdal/2.4.0/gdal240.zip - source as a zip
* http://download.osgeo.org/gdal/2.4.0/gdal-2.4.0.tar.gz - source as .tar.gz
* http://download.osgeo.org/gdal/2.4.0/gdal-2.4.0.tar.xz - source as .tar.xz
* http://download.osgeo.org/gdal/2.4.0/gdal-grass-2.4.0.tar.gz - GDAL-GRASS plugin
* http://download.osgeo.org/gdal/2.4.0/gdalautotest-2.4.0.tar.gz - test suite
* http://download.osgeo.org/gdal/2.4.0/gdal240doc.zip - documentation / website
The migration guide can be found at :
https://github.com/OSGeo/gdal/blob/release/2.4/gdal/MIGRATION_GUIDE.TXT
Best regards and Season's greetings,
Even
http://www.spatialys.com
More information about the gdal-announce
